Join Wall
Join Wall
GHASEM_ARIYANI
Advisor Advisor
Join Wall
GHASEM_ARIYANI
hi
I want Wall Arch Picture below With Side walls Join But it does not connect properly and reasonably
Please help if you can.
Attache Join Wall.rvt and Saved Revit 2014
GHASEM ARIYANI
BIM/VDC Manager
Revit Architecture Certified Professional
Revit Structure Certified Professional
Revit Mechanical Certified Professional
Revit Electrical Certified Professional
If my answer solved your problem, please click "ACCEPT SOLUTION" and consider giving a Kudo.
LinkedIn
YouTube
Udemy Course
Try joining the two walls then modifying function of wall layers 1, 2 , 6 & 7...
GHASEM_ARIYANI
Hi
Thank you for the reply .But there is a problem.
See the picture below.
GHASEM ARIYANI
BIM/VDC Manager
LinkedIn
YouTube
Udemy Course
Depending on the scale of your drawing on the sheet that may not be seen???... bigger fish to fry
GHASEM_ARIYANI
However, this should not There is Solutions must be found for.
Cost estimates are wrong because.
GHASEM ARIYANI
BIM/VDC Manager
LinkedIn
YouTube
Udemy Course
constantin.stroescu
a workaround can be to make a: Component > Model in Place > Family Category and Parameters > Walls >Name > Extrusion - make a Void and Cut the extra wall with it....
Constantin Stroescu
GHASEM_ARIYANI
Dear Friend
I know But I want to know Is there a way to have their walls This situation can be corrected Model-In-Place and need not
GHASEM ARIYANI
BIM/VDC Manager
LinkedIn
YouTube
Udemy Course
