Join Staircase with Columns, Beams and Slabs
fahim_108
fahim_108
Is there a way to join a cast-in-place staircase and its landings with surrounding civil elements - like columns, beams, slabs etc?
RDAOU
@fahim_108
Stair elements do join with floors but even if both have the same material, you wont be able to get rid of that line at the joint except in 2 cases:
  • if you use invisible lines (switch join order of the beam and floor first)
  • if you convert the stairs to a generic model (which eventually will happen if one needs to add/host reinforcement)
