I'm working on creating a simple window family from scratch and I'd like to create a parametric panel with grilles that I can later add to other window families. I created the grille as a separate generic model family then loaded it into the host panel family so I can make an array for the grilles. I haven't quite figured out the array part, but I know that in order to snap anything to the centerline of the grille it first needs to be a nested family otherwise there is no centerline on the grille to align it to other things. If this is not the case, I can create the grille within the host family and it will join fine, but as is, the nested grille will not join to the panel generic model. If there is another way to accomplish my end goal without having to first figure out how to join the nested generic model to the host family, it would be great to know, but if there is no way to join them and accomplish my end goal of creating a parametric array for the grilles, then so be it. I'd just like some advice and help with this project. Thanks!
