Message 1 of 12
11:15 AM
- Mute
- Permalink
- Report
Hey,
so I'm modelling a handle to a desk right now and since it changes profile along its path and is symmetrical I have modelled half of it through swept blend and then mirrored it to create the other half. After that I joined them through "join geometries".
The only problem I have is that now it won't join together visually. When you try to select it both halves act as one object, but you can clearly see the line in the middle as you can see on attached screenshots.
Any ideas?
