Join Geometry: Common Line
XXalessio.amodioXX
Message 1 of 11
XXalessio.amodioXX
Hi all,
I Want to know if it is possible to preserve a common line after joining to elements with same material.
N.B. I know it is possible to assing different matariel to the elements but it will cause issue in scheduling.
Linework not an option.
Replies (10)
Message 2 of 11
syman2000
You can override the cut.
All I use is the same color as the original solid gray color and modify one value so it is slightly different. You will see a light line showing.
Message 3 of 11
XXalessio.amodioXX
I have tried to override by element as you described but still line not visible.
Can you record a screen cast or short video ?
Message 4 of 11
ennujozlagam
no you can't, just extend the other wall and delete the short one. thanks
Message 5 of 11
syman2000
Did you modify the cut pattern color to 127-128-128?
Message 6 of 11
XXalessio.amodioXX
Yes.
Whatever color I override same result. after joining no visible common line.
Message 7 of 11
martijn_pater
Could just unjoin them? Or draw a detail line? But I guess it's more of a question in general...
Message 8 of 11
XXalessio.amodioXX
I think that maybe it is the best solution. Keep them unjoinded and override the common line.
Message 9 of 11
syman2000
Did you override by element? This is how I get the line show up because i just override one of the wall to have slightly different color than other wall.
Message 10 of 11
XXalessio.amodioXX
maybe because they are floors (?)
Message 11 of 11
syman2000
I apply the same technique and it works fine. Only way to figure out is to upload the file.
