Issues with Window not showing Mullions
jgarciacorpus69
Message 1 of 23
jgarciacorpus69
I am trying to figure out why, the mullions on my windows do not show up. I clicked on the window, and it shows the mullions but on the revit file they are invisible, and they are not hidden. The material is there, so that material should show up on the window.
Here in this picture, it shows what is highlighted.
Replies (22)
Message 2 of 23
EATREVITPOOPCAD
Post simplified Revit project with problematic window. Could be a few things, visibility type or instance properties, view detail level, etc...
The definition of insanity is doing the same thing over and over again and expecting different results
Message 3 of 23
jgarciacorpus69
I am checking not I am not sure what it could be wrong with it.
Message 4 of 23
Looks like the Material is using Illumination.  Check the Asset to see if Self-Illumination is checked. Uncheck it if it is.
Message 5 of 23
jgarciacorpus69
It is not self-illumination, the reason it was showing as transparency was because I selected the mullions. The materials are set as Clad- White and should be shown in that material. I am still stuck.
Message 6 of 23
How about we do not play the guessing game and just look at your file?  Sound good? If so, post your file here.
Message 7 of 23
EATREVITPOOPCAD
you should take a single wall with one window, paste it into an empty revit project file, and upload it here so we can quickly identify the problem
Message 8 of 23
Actually, I prefer to see the file that the Window it is in.
Message 9 of 23
jgarciacorpus69
Here is the file just the separate window and here is the full file
Message 10 of 23
What's the View's Detail Level. Fine?
Message 11 of 23
jgarciacorpus69
yes why ?
Message 12 of 23
Nested Muntin Family Visibility Settings:
Message 13 of 23
jgarciacorpus69
What do you mean ?
Message 14 of 23
Set the view in the project to Fine.
Message 15 of 23
EATREVITPOOPCAD
View visibility detail level and I got to see mullions
Message 16 of 23
What do you mean ?
Message 17 of 23
EATREVITPOOPCAD
@ToanDN @barthbradley Man you guys are quick lol
Message 18 of 23
jgarciacorpus69
I see the mullions thanks! But I want to fix another issue with the wall 😞
Message 19 of 23
The one I posted will work at all Detail Levels.
Message 20 of 23
EATREVITPOOPCAD
Post the problem 😄
