Issues with Structural Views
Issues with Structural Views (of structural plans that are beginning to be prepared on a set of architectural plans, and the structural settings were transferred using "Transfer Project Standards" from Revit's 2020 Structural Template):
1. On an existing building which is being drawn, on the plan the grid line number “2” shows as a number "2.1" inside its bubble, and when an attempt is made to change the number inside the bubble to the number “2”, it indicates that it already exist. The sequence is correct from now on, 2, 4, 5, etc., except for that unwanted number 2.1. I do not see the number “2” grid anywhere on the plan so it could be moved or changed, and the unwanted “2.1 is still there.
How could I find the “hidden” number “2” grid line with its circle (or without the circle?).
2. The second and floor structural plans show the elements that were transferred from a structural template, but do show the exterior existing tilt up walls that are to remain. I went to visibility graphics dialog and these are clicked with a cross, so I wonder why they are not seen. I believe it is desirable that these existing concrete tilt up wall are seen on that plan also, in addition to the interior steel columns (these show OK now). How can these concrete tilt up walls be visible on these structural plans?
