Issues with Revit keynotes
anien63RK2
anien63RK2
Good day
Please may you assist with a Revit keynote issue. Key notes have this warning when you try to reload them from the same location. Image attached. I have to save to 2 different locations and pick the first save option again, basically we double saving keynotes.
ennujozlagam
you can refer to this LINK and see if helps. thanks
anien63RK2
Hi
ennujozlagam
it could be there is a administrator rights in your server?check with your IT Manager. i guess. thanks
After save the excel file as the text file to load in revit, do another save as to another txt file with a different name and keep it open in excel. Now you can load the 1st one in revit. When you need to edit, just do 2 saves like that and you will have no issue.
