Issues synchronizing over local network
Message 1 of 21
I work for a small design firm. We use Revit versions 2016-2020. I have been having issues syncing my local files with our central models for about a month now, across versions 2017, 2018 and 2019. We store central models on a network drive (Q:) and local files to the standard My Documents location.
When I attempt to synchronize with the central, I get the error message: "An unknown error occurred while accessing \incrementtable.dat" The file name varies but it is always a .dat.
We have cleared all local files from my documents and emptied the recycle bin. I have tried resetting the network and remapping the drives. The fix is always only temporary.
I am happy to provide any more info you need. Thank you,
Rae
Replies (20)
Message 2 of 21
s.borello
Does this happen to all users or just you?
Message 3 of 21
Just me, unless someone is working on the same project at the same time, then they receive the same error message.
Message 4 of 21
ennujozlagam
all user's working with the central file must be the same Revit version build. try to check. thanks
Message 5 of 21
Confirmed that we all have the same build.
Message 6 of 21
ennujozlagam
try to create a new local file and see if helps. thanks
Message 7 of 21
RobDraw
Try a different network connection to see if it continues.
Rob
Message 8 of 21
I've tried making a new local and saving it to both a network and a local
folder. I've tried saving a new central from my local file that I still was
not able to synchronize to.
Message 9 of 21
Unfortunately, that isn't possible. We are wired through ethernet to our private network.
Message 10 of 21
RobDraw
Of course it's possible.
Unplug the ethernet cord. Move the computer to someplace else where you can re-plug in. Experiment.
Rob
Message 11 of 21
Just to clarify -  you're asking me to plug into another ethernet port that connects to the same network?
Edit: I was told that we've tried that with the other port in the wall plate. We have yet to test a completely different wall plate but that would require I lose my computer for a while so I'll let you know when we get a chance to do so. Thanks!
Message 12 of 21
David_Knight
have you tried disabling your anti-virus? this is a weird one, not sure what the issue might be - but i would try that to see if it is somehow impacting the problem.
also, could the server be placing a lock on the file (the .dat file) - and not releasing it?
Message 13 of 21
RobDraw
I've wasted too many hours trying to track down similar issues only to find out it was a bad network connection that I tend to check these things early. If moving the computer is too much of a hassle, you could change out the cord. I've had cords go bad, too.
Rob
Message 14 of 21
That makes sense. We will most likely just move the computer, our ethernet cables are not long enough. I will also suggest we try switching out the cable to make sure that isn't the issue.
Message 15 of 21
Revit is allowed through the firewall, is this enough or should I try actually disabling it entirely? The file does not seem to be locked - it was easily moved to another location so it seems to not be in use by any processes.
Message 16 of 21
Matt__W
Have you seen this AKN about that message?
"AN UNKNOWN ERROR OCCURRED WHILE ACCESSING ... INCREMENTTABLE...DAT" WHILE CREATING NEW REVIT LOCAL ...
Matt Wunch
Revit Subject Matter Expert/sUAS Pilot
Twitter | LinkedIn
AU2017 - Code Blue Dr Revit - How to Resuscitate Corrupt Revit Models
Was this answer helpful? If so, please click the ACCEPT AS SOLUTION or the KUDO button.
Message 17 of 21
Yes.
Message 18 of 21
timlanepba
I've had exactly this problem for several years now with various versions of Revit from 2016 onwards and it has been driving me up the wall.  I have tried everything I can think of but still no proper solution. In brief:
  • It only seems to occur on a couple of workstations - mostly mine and occasionally one or two others.
  • Our central files are located on a network file share (Windows Server 2012) - local files are always on the desktop of the workstation
  • When I get that message, the fix is to reset the network card by disabling/reenabling in Windows control panel.  Until I do this I cannot sync to central
  • Weirdly, the issue is much worse when working directly at the workstation.  If I am working from home via remote desktop, I rarely get the message
  • Initially thinking it was a problem with my workstation, I tried all of the following (and more besides) but nothing worked (1) move the computer to another network socket (2) bought a usb to ethernet adapter (3) tried wifi instead of wired (4) reinstalled windows (5) reinstalled Revit (6) disabled AV...
  • I got to the point where it was happening up to 8-10 times per day which was really frustrating.  Thankfully it was only really affecting me, so I could put up with it and it wasn't affecting other staff.  I would periodically get days or even a couple of weeks where it didn't happen at all.
  • At the time it was at it's worst, I was mainly working on one particularly large workshared project.  To try and isolate the issue and see if it was somehow related to the server, I set up a file share on an old computer and moved the central file to this rather than our main server.  Magically, I never got the message again when working on that project.  However, as soon as I would work on anything stored on the main server, the message would return
  • I got a new workstation about 6 months ago - partly as a last-ditch effort to see if it was a hardware issue with my previous workstation.  All seemed ok initially... then lockdown happened and I worked exclusively at home until we reopened the office in late June.
  • I have now started getting the same messages on my new computer when working on some (but not all) central files saved to the main server - and (thankfully) nowhere near as ofter as previously... maybe once a week or so.  As previously, a reset of the network card resolves and allows me to sync.
I am convinced that it must be some process on the server that is locking the file, but I am none the wiser as to what it might be.  Any suggestions would be most welcome to finally put this one to bed!
Message 19 of 21
CHRISSIMS7803
Did you ever figure this out? I have had the same issue for months and haven't been able to resolve.
Message 20 of 21
timlanepba
No solution other than resetting the network card (which is problematic when working remotely!) or offloading the central file to a shared folder not on our main server. It does seem to only happen to certain projects and (thankfully) only on a small number of workstations. Autodesk tech support suggested it might be a corrupt Windows User Profile, but I tried to make a new one and still had the problem. As a workaround when remote working, I created a small batch file that will disable and then re-enable the network card... The commands are:
netsh interface set interface Ethernet disable
netsh interface set interface Ethernet enable
