I tried asking this in the MEP forum but didn't get a reply. It's a family issue anyway so I figured you architects would probably know the answer so I'm re-posting here.
I am trying to create pan & tilt parameters in an existing CCTV camera family.
The wall bracket needs to remain fixed, whilst the camera and stem rotate about a pivot point in both horizontal (pan) and vertical (tilt) planes.
Starting with the pan angle, I have created a 45° reference line from the desired pivot point but I'm stuck at the first hurdle because when I try using the align tool to lock the end point of the reference line to the pivot point, I get the following error message.
The Dimension would overconstrain the Sketch.
There don't appear to be any other dimensions or constraints in the family that would give this error.
Please can someone take a look at the family and see if you can figure out why I'm getting this error? I'm using the Left Elevation view.
