Creating toposolid from csv - no points found
blank...
Advisor Advisor
blank...
I'm trying to create a toposolid from a csv file, but I'm getting "No points were found in the file" no matter what I try.
This is how file looks when opened in Excel
I tried saving it as a txt (ms dos), but that didn't help either.
Csv file attached.
Units are meters, C column is the height, A and B columns are coordinates used by surveyors in my country, from geodetic reference system they use, that's why they're enormous.
RDAOU
@blank...
It is using a separator (delimiter) other than a comma. For example, if the number formatting in Excel is set to follow Windows regional settings where ; is the separator, Revit will not be able to read these points.
Option A: Go to Windows Control Panel >> Region >> Advanced settings >> Format tab >> List Separator Change the separator to a comma ( , ). Then, resave the CSV file.
Option B: Open the CSV file in Notepad, then use Find and Replace to replace all ( ; ) with a comma ( , ).
blank...
@RDAOU wrote:
  • Option B: Open the CSV file in Note Pad, then find and replace all ";"or whichever separator that csv is using with "," comma
This was it! Didn't think to check in Notepad how Excel exports it.
Thank you!
