Issue with Razer Synapse? Or Issue with Revit?
ronsarlo
Message 1 of 1
ronsarlo
I recently picked up a Razer Basilisk V3 X Hyperspeed to use for work.
I've installed the latest version of Razer Synapse.
I'm using it with Revit 2024.
I'm trying to map very simple 2-key keyboard macro shortcuts such as:
"MV" for move. and "AL" for align.
In Synapse, I'm using "Text Function", and I type in the text string "AL".
Just as a sanity check, I test this out in Notepad and it seems to work.
Within Revit, I'm testing it inside a text box, and it also seems to work.
Unfortunately, in a Revit plan view, the macro bound to the mouse is not working.
As an additional check, In Synapse, when I use "Keyboard Function", "Key Recording" and record a single key "J" for join.  As expected, that single key does seem to work in the Revit plan view.
So I’m seeing a bit of inconsistency here.
I'm unsure if this is a Razer Synapse problem, or if it's an Autodesk Revit issue.
Because it’s a simple 2-key macro, it should be fairly straight-forward?
Is there something in Revit that would prevent Synapse from punching in simple keyboard keys?
Surely I'm not the first person to use a Razer mouse for Revit.
I've been using Logitech gaming mice for 15 years using these same macros without issue.
I'm very confused.
Would be glad for any help you can provide.
Replies (0)
