Issue with Property Line table
khbrake
khbrake
I am having some issues entering in property line information. There is no way for me to direct the line to start N/ S or E/W. Is there a code or something I am supposed to use?  The last time I used this feature, I was able to define this. I have since upgraded to the full REVIT and feel like I missed something. I have looking for an answer and any help I see screen shots of the table that I used to use that has a separate column for the direction.
RDAOU
@khbrake
The property line is not yet closed... it needs to be a close loop for you to have access to N/S field...see the tab ADD LINE TO CLOSE? click and finish the loop...Once done that option should be grayed out and you will have an extra column for N/S
