single room missing from the model
9 ANTWORTEN 9
Nachricht 1 von 10
s.sotiriou
858 Aufrufe, 9 Antworten
Hi All,
For some mysterious reason I'm unable to select one of the room in my model - the room tag is still there but the room itself it's gone missing!? I also can still see/select other rooms and areas... It's just this one (the Bathroom room), some time ago I've moved it temporarily from one apartment to the other and when I wanted to move it back it's gone...
Please advise
9 ANTWORTEN 9
Nachricht 2 von 10
syman2000
als Antwort auf: s.sotiriou
Couple of things you can check.
1. Is there a roof or ceiling close to floor? Often those roof or ceiling is room bound and will hide the room
2. Check to see if there is plan region which set to upper level
3. Check and see if the room has offset
4. Check and see if the room is set to volumetric rather than area. Volumetric will contain room within wall, floor, roof, ceiling. If the room cut thru two floors, it will contain only at the level below.
Nachricht 3 von 10
RDAOU
@s.sotiriou
So you see this room Marked in Red... Overlaying the other rooms? Could that be your Bathroom by any chance???
Drag and drop it on the other side...
Nachricht 4 von 10
s.sotiriou
als Antwort auf: RDAOU
Hi @RDAOU , thanks for your reply. The "room" you have marked in red is actually an Area "2B4P" (GIA of the whole apartment) and it's exactly where I want it to be...
Nachricht 5 von 10
s.sotiriou
als Antwort auf: syman2000
Hi @syman2000, many thanks for your reply. See my comments:
1. There's no ceiling, no roof, no slab above/close to the floor.
2. There's no plan region either.
3. & 4. I'm unable to check that because I can't select the room - that's the whole issue...
Nachricht 6 von 10
ahjorn
Hi @s.sotiriou
You have a section running through the room. Are you able to select the room in the section view?
Nachricht 7 von 10
syman2000
Upload the sample file so we can take a look more carefully.
Nachricht 8 von 10
Corsten.Au
1. Make sure that room is associated to correct level ( you can get this by Room Schedule, Associated level, name , area etc )
2. your best best is , create a schedule, and delete that room.. ( Deleting a room on the floor plan, or moving or by mistake making unclosed room ) won't delete that room from the project..
3. Just delete that room and recreate it on correct level and make sure its enclosed. and then tag.
Corsten
Building Designer
Nachricht 9 von 10
s.sotiriou
als Antwort auf: Corsten.Au
@Corsten.Au
I thought of it but I cannot find that particular room even in the schedule! Weird.. Eventually I just deleted the tag and created new room where I needed. I know it's not a perfect solution and that room is still somewhere in the model but as it doesn't even shop up in the schedules...
@syman2000
Unfortunately I'm not allowed to upload this - its fairly sensitive work stuff...
@ahjorn
Nope, even in the section I can't see/select that room...
Nachricht 10 von 10
ahjorn
I have to admit that this is really weird behaviour for a room element.
