Issue with changing length of arrayed group in family
Message 1 of 27
So I'm trying to make an array group's length to be parametric to the overall width of the family.
The ends of the joists are locked to the appropriate reference planes (the ones 3" off from the total width reference planes).
Before doing the array, it works fine when I change the width by both dragging the reference plane or changing the value on the properties window.
But as soon as I make the array and change the width on the properties window, I always get an error with the groups or are forced to remove the constraints. It works fine dragging the reference plane though.
What could be the issue?
Replies (26)
Message 21 of 27
I was able to get it to work finally!
Instead of creating the generic extrusion inside the host family, I made a new generic model family just for the joist member and then import that into the host family and now everything works!
I don't know why I haven't tried this one before.
Thanks All!
Message 22 of 27
Yes, that's what we've been saying. The Array element needs to be a Nested family and it's length needs to be controlled by parameter in the Host.
Message 23 of 27
Sahay_R
Ummm - just what I had said in Post#7.....
Rina Sahay
Autodesk Expert Elite
Revit Architecture Certified Professional
Message 24 of 27
Oh! I see that now-!
When I saw it beforehand, I was only thinking about the HSS member family that I already had nested-
And all the steps you've outlined is exactly what I was doing with it so didn't know where else to go from it-
Message 25 of 27
@Anonymous: You can credit more than one solution. Heck, give yourself one too! Smiley Wink
Message 26 of 27
Sahay_R
Aaahhh, the joys of having a loud mouth - or, in this case, a loud keyboard.....
Rina Sahay
Message 27 of 27
That's not what they're asking.
