Hi ! I have a really problem to paint some component wall, when I try to paint it the windows are imediatly cover... can someone help me, what can I do in this case?
PS: The front face of the building, 2 levels are component walls cuz the interios are very complicated and I have no choise
What do you want to paint that for? Wouldn't it be much easier for you to put an overlapping family?
Roi G. | AUTODESK REVIT & DYNAMO EXPERT
Da un "Me gusta" si la respuesta te ha resultado útil y acéptala como solución si ha resuelto tu duda.
Give a "Like" if the answer has been useful to you and accept it as a solution if it has solved your doubt.
I want to make a randering for marketing and it need to be like in reality
Looks to me like the problem is the Window itself. Is it cutting all the way through the Wall?
Post your file here.
In the plan view the window seams to be ok, but the paint change the face of the wall.. maybe it's problame cuz it's a component wall?!
Post the RVT file here as an Attachment to a reply post. We can then tell you exactly how to resolve your issue.
The file is too big to put it here... It kills me, I really don't know what to do
Replace the void in the window family with a cut opening.
