is there an actual/efficient tool in Revit for achieving wall suppression in faceted shapes?
pacmaniel
pacmaniel
Community Visitor
Community Visitor
Hello and thanks for reading. 👤
Im new to revit but,
Is there a practical way to use the tools provided by Revit to achieve the remaining suppression of walls so that it matches the faceted shapes of the structure? At the moment, I'm doing it manually with the wall lines, but this is very imprecise and time-consuming.
Due to the irregularity found within the structure, each room and module will require different wall configurations based on the faceted shape it needs. Therefore, a cutting tool between walls and facetted shapes that ends in the suppression of excess protruding wall would be ideal for a quicker, more efficient integration. However, the cutting and joining tool often presents errors or does not allow me to select as desired.
lucdoucet_msdl
@pacmaniel
In the same manner you are creating walls by face using the volumetric family, create roofs by face for the sloped tops. Then attach the walls to the roof elements as in this help article:
Attach Walls to Other Elements
Hope this helps,
-luc
Create roofs and attach walls to them.
handjonathan
Hi @pacmaniel
Thanks a lot for posting your question to the forums!   Have the solutions suggested by @lucdoucet_msdl @ToanDN helped with your issue?
We look forward to hearing back from you with more information so we can help you as a community! 
Jonathan Hand
Technical Marketing Manager | Construction
