Is there a way to print PDFs from multiple RVT projects at the same time?
joshfelty
joshfelty
Is there an add-in, Dynamo method, etc. that could export PDFs and/or CAD dwgs from multiple RVT files at the same time?
My firm often has multi-building projects, with each building getting its own RVT project (for technical & drafting reasons). I'd prefer not to open and print each building's set of drawings, one at a time. A batch print of all buildings (they're linked into a single "site" file) would be great if possible.
L.Maas
I have used Revit Batch Processor in the past.
What it does is that it loads multiple Revit projects and then exceutes a Dynamo Script (or Python).
So if you have/make a dynamo script for printing PDFs from a project you then can batch that with RBP.
Louis
Please mention Revit version, especially when uploading Revit files.
