Is there a way to do a polar array with different angles?
evelyn_barboza8FFLK
evelyn_barboza8FFLK
I'm new to Revit, and I'm trying to create a parametric polar array where I can define the number of elements, the radius of the array, and the angle between each pair of elements. I want the angle to vary between elements — for example, between element 1 and 2 it would be 37.5º, but between element 2 and 3 it would be 45º. However, I don't know how to make this third parameter work. Is there a way to do it? I assume that if there is, it's not as straightforward as creating a regular array.
azad.Nanva
make the group of them, if i have the vision over it maybe can better help.
{(element 1,element 2)<37.5 group one
(element 3,element 4)<45 group two} array this group.
evelyn_barboza8FFLK
I want the angles to be also parametric
azad.Nanva
give me a vision, screenshot or something else.
RSomppi
By definition, that is not a polar array.
mhiserZFHXS
What are some specifics on this? Like are you doing with this with the same element multiple times in multiple projects, or is this a one time thing? Odds are you'll just want to place all of the elements individually. But if this is something you do with one particular element multiple times in multiple projects, you could consider making a family for it.
