Is there a switch mode to not select unnamed reference?
Sleepingfish_Kuo
Message 1 of 10
Sleepingfish_Kuo
I'm editing a lot of family now.
And I need to lock nest family to my current family, but I pick wrong reference often.
When lock only "reference"(the instance edge of nest family), it cause error when changing the size.
Can I change some setting to not pick the unnamed reference?
Or just tab tab tab tab...
*Edit: Add a simple file to show a nest family with too much solid edges and what's going on when locking wrong reference.
Replies (9)
Message 2 of 10
RC_RVT
You could use temporary hide to your advantage if you are repeating this task a lot. Doesn't exactly answer your question though, but there isn't an option for this as far as I know.
Message 3 of 10
Sleepingfish_Kuo
Thank you, I'll try hide others.
But I can't hide the nest family's  instance itself but keep seeing the stronger references.😥
Message 4 of 10
azad.Nanva
did you try to new Subcategory of Reference Plan? so you can hide the your subcategory!!
(view in My Videos)
and for the nest family you can make them Not a Reference:
Message 5 of 10
Sleepingfish_Kuo
I knew how to use subCategory and "IsReference".
I'm not worry about select wrong reference plane, but the solid edges (or model lines, detail lines, too).
They jump out as a reference when I try to align reference plane as a reference for a nest family's reference.
Message 6 of 10
azad.Nanva
If i understand well,you need to use the TAB to select the right one.I had this problem too for manage the nested family .I solved my problem in another way,could you post a simple family?
Message 7 of 10
Sleepingfish_Kuo
OK, I update it in the first post.
I'm using tab tab to pick the right one, too.
Just want to know if there is a better method.
Message 8 of 10
azad.Nanva
This is good quastion and I can help!
we have two sulotion here:
1- you have the L so you just need to lock one side and use the define the L
(view in My Videos)
2- change the nested family
Message 9 of 10
Sleepingfish_Kuo
Sure it works, but no where to hide these counting parameters.
If I do that for my actually working family... I'll get more than 50 parameters.
(Just a simple, if the nest family's length is not L, but L-r.
Then I need to create another "L-r" parameter for it.)
Or maybe I should give up control some of them, let it be a fix, uneditable family.
And build new family again and again when I need to change something.
Message 10 of 10
azad.Nanva
This is the easiest solution , I can not understand why you should build the family again and again?this is three family nest in one to explain, and yes you should have the L this is normal,or L-something,We should know ,we use the Revit not Magic Wand.
