Is there a calculator in revit?
emmanuelbee
Message 1 of 12
emmanuelbee
is there a way to make quick calculations of numbers etc in revit rather than always having to open the windows calculator app for calculations ?
Replies (11)
Message 2 of 12
You can enter a formula directly in a dimension string, for an instance.
Message 3 of 12
You can totally do long addition too....so 8+6+7+5+3+0+9 will give you 39. 😛
Message 4 of 12
...oops
Message 5 of 12
ccastelein
didnt answer the question to original post... does it have a calculator...
like how many 18" in 200'
Message 6 of 12
=200' /18" when modifying a dimension...
If you are looking for a little calculator button that pops up a calculator like in Windows, then no, it doesn't have one.  Keep a shortcut in your taskbar if  you need a separate calculator app.
Message 7 of 12
=round(200'-0"/1'-6")
Smiley Wink
Message 8 of 12
ccastelein
i wasnt trying to put in any dimension i just want to know/or calculate a feet and inches question... basic windows calculator (to my knowledge) doesn't do feet and inches, and the free calculator from windows, that does, kinda sucks. Acads works nicely... thought autodesk would put it in revit, seems it would be easy to do..
Message 9 of 12
I'm sure someone can do better....but this took a minute or two...
Oh...and Autocad is a totally different UI than Revit.  So if Revit was to have a calculator button it would probably just popup the Windows version.
Message 10 of 12
mhiserZFHXS
Dear god Autodesk... please get these spam-bot accounts under control...
Message 11 of 12
RSomppi
You can report those posts to help out.
Message 12 of 12
arq_42
Unless you're still on Windows XP, the Windows calculator does conversions. 😄
Click on the little lines at the top left, and there you have all kinds of calculators.
The Google search engine does this too if you type it directly.
And if you want something even faster, PowerToy for Windows has "Power Toys Run", with which, among other things, can do quick calculations by pressing "alt+Spacebar"
¿Te resultó útil esta publicación? Dale "Me gusta".
¿Tu pregunta fue respondida correctamente? Haz clic en "ACEPTAR SOLUCIÓN".
