Is REVIT a good tool for Real Estate Developer/Owners to use for project management?
michael6V9S8
Observer Observer
Message 1 of 9
michael6V9S8
Observer
Observer
Is it worthwhile to invest in and learn REVIT from a real estate developer's perspective? It *seems* like it would be an excellent project management tool- but wanted some feedback from users and others in similar circumstances...
Replies (8)
Message 2 of 9
constantin.stroescu
not quite.. Revit is ,indeed an instrument of BIM , but for Design purpose.
For a Real Estate Developer/Owners you have to look for other BIM softwares:
https://www.softwareadvice.com/construction/real-estate-development-comparison/
Constantin Stroescu
Message 3 of 9
michael6V9S8
Observer
Observer
Ahh ok…let m refine my ask then…
My Contractor, Architect, Construction Manager, and Interior designer ALL use REVIT and 360…
So, as an architect myself by background, seemed like it would be a BETTER fit to bite the bullet so to speak, and go right to the model….
Meanwhile, I will take a look at the link you provided so THANK you !!!
##- Please type your reply above this line -##
Message 4 of 9
constantin.stroescu
all BIM 360 (Docs for AEC Collection comes with Revit full option and the entire construction collection) are necessary for all project stakeholders....
Revit for Designers , Navis Work for Contractors and so on.... As a project manager is good to have an idea of all the software used in all the four stages of BIM implementation.
Constantin Stroescu
Message 5 of 9
michael6V9S8
Observer
Observer
My Contractor, Architect, Construction Manager and Interior designer ALL use REVIT and 360…
So, as an architect myself by background, seemed like it would be a BETTER fit to bite the bullt so top speak, and go right to the model….
Meanwhile I will take a look at link you provided so THANK you !!!
Message 6 of 9
alexanderallan568
Community Visitor
Community Visitor
Investing in and learning Revit can be worthwhile for a real estate developer, as it helps with efficient project planning, design visualization, and collaboration. Its features allow better management of complex designs and integration with other tools, improving overall workflow. Feedback from users often highlights its ability to streamline processes and reduce costly mistakes during construction.
Message 7 of 9
mattewwade06
Observer
Observer
From a real estate developer's standpoint, Revit can definitely be a valuable tool especially during the planning and pre-construction phases. It helps visualize the project in 3D, coordinate with architects and engineers, and avoid design clashes early on.
While it's not a complete project management solution in itself, it does support better decision-making by giving you a clear spatial understanding of what you're developing. We’ve seen developers, especially in urban markets like London, use it to streamline planning for mixed-use or rental-heavy developments.
Based on what we’ve worked on with London estate agents , having accurate visual models from the start can also speed up approvals and improve communication with stakeholders.
So yes if you're hands-on with your projects, learning Revit can give you a practical edge.
Message 8 of 9
bushra_bhatti
Community Visitor
Community Visitor
REVIT is powerful, but it's primarily designed for architects and engineers—not as a core project management tool. For Real Estate  developers or owners, it can be valuable for visualizing design intent, coordinating with consultants, and catching conflicts early.
That said, for actual project management—scheduling, budgeting, and oversight—you’d likely get more value from pairing REVIT with tools like Procore or MS Project. Learning the basics is worthwhile, but you probably don’t need deep REVIT skills to manage effectively.
Message 9 of 9
HVAC-Novice
Revit is very flexible and people use it for all kind of applications... but there is quite a learning curve and and a dedicated PM software likely is much more suitable.
if you own a license already, you can try and compare to other tools you have access to.
Ultimately Revit is optimized for building design and creating construction documents. Not Civil engineering. Not plant engineering. Not a scheduling tool. Not a cost estimating tool.
Revit Version: R2026.4.2
Hardware: i9 14900K, 64GB, Nvidia RTX 2000 Ada 16GB
Add-ins: ElumTools; Ripple-HVAC; ElectroBIM; Qbitec
