Is it possible to use a formula and drive Family Type parameters?
KraiggC
KraiggC
Is this possible? What I'm trying to do is drive visibility based on options of a family. For simplicity's sake, I have a nested circle and hex family. If Circle is checked then the family is visible, but if hex is also checked then the family changes to hex shape. The hex option only drives the change to hex shape, where the circle option drives whether the shape is visible or not.
KraiggC
Thanks to this post I was able to find the solution:
If statement for family type parameter - Autodesk Community - Revit Products
nozci
I think this shows both circle and hex at the same time. Is this what you want?
pessi.symb
Like this? :
RC_RVT
in addition to this.
have "circle" as you have, with no formula
have "hex" set to: not(circle)
This will mean that when circle is selected & visible, hex will not be selected and when circle is unselected, hex will automatically be selected & visible.
This will prevent the possibility of both circle and hex being ticked at the same time.
(view in My Videos)
