Is it possible to resize named scope boxes
Message 1 of 16
Hi everyone,
I'm working with a very complex model with a lot of sheets.
In the model I want to resize te scope boxes of a floor plan.
These scope boxes are named so they can't be resized by using the grips which are normally displayed.
Does anyone know if it is possible to resize another way?
Thanx in advance.
Replies (15)
Message 2 of 16
You can resize them in a 3D or plan view.
You're probably asking about the crop region when a view has been assigned with a scope box, where you can't change the size of the crop region.  Then you can resize this in a 3D view, which will adjust the crop region.
Message 3 of 16
If I open a 3D view and assign the scope box I still can't change the size of it.
There are no grips visible for the designated scope/section box
Greetz, Bjørn
Message 4 of 16
Don't assign the scope box to the 3d view.  If you need it to be assigned to the view then first set  the scope box to none and adjust the size. Then assign the view.
Message 5 of 16
RobDraw
In a plan view, hide the crop region and make sure scope boxes are on. Select the scope box and the grips should be there.
Rob
Message 6 of 16
Unpin them.
Message 7 of 16
Hi.
They already are unpinned.
Message 8 of 16
RobDraw
Reread the entire thread. All the information you need is there. If you follow all the instructions and still can't resize it, post the file.
Rob
Message 9 of 16
GlynnisVP
As Rob said earlier, it sounds like you might want to un-assign the scope then resize then re-assign.
I made a quick video: https://autode.sk/2HvuLtL
Best Regards,
Glynnis Patterson
www.ideatesoftware.com
Message 10 of 16
RobDraw
@GlynnisVP wrote:
It sounds like you might want to un-assign the scope then resize then re-assign.
Already stated in message 4.
Rob
Message 11 of 16
Greetz, Bjørn
You need to open a non-cropped view, so do not assign that scope box to the view you want to see it.  It is a good idea to have a non-cropped working view for each level so you can see everything.  Then you can just select the scope box , stretch the grips and your other view(s) will be updated arcordingly.
Message 12 of 16
You only can do it if you don't have a view already with that specific scope box assigned.
Message 13 of 16
hanksteinhardt
Same problem x2. I've unassigned the problem scope box, but there aren't any other views that is visible in, because I went through to scope box assignment dialogue and made them all invisible except the view that I need it in. So now I can't size, or delete it!
Message 14 of 16
RobDraw
Did you try doing as suggested in the post marked as the solution?
Rob
Message 15 of 16
A-Rahaman
Observer
Observer
Make sure you unpin them after that
Message 16 of 16
Keaston_Swaby
Thank you for the video and patient reply, Glynnis. Having a visual to go along with the written explanations helped a lot!
