Is it possible to export project standards to an excel file?
jquarry
jquarry
Hello. I am wondering if it is possible to export Revit 2023 Project Standards to an excel file where I can then import it into a Revit 2022 or earlier file?
I have all of my standards in my 2023 template and need to somehow copy them to a Revit 2022 required model.
I have both CTC and DiRoots suites of software to work with. Using one of them would be ideal, however, if there are other tools at my disposal then I would be all about them as well. Any help and/or experiences are appreciated.
TIA
nmarcelis
Hi this is the achilles heel of Revit.
There simply is no way of transfering project standards between a model in a newer version and an older version, without upgrading.
I would suggest you to recreating your project standars in the oldest version you think you will need in your projects.
Whenever you need to transfer them, upgrade a copy of your masterfile and transfer the project standards.
Regarding exporting and importing project parameters, it will be difficult and long.
Revit Certified Professional Architecture, Structure and MEP.
jquarry
No i fully agree, but in this case we did not foresee the continued use necessary for a few clients. So now we are here and it unfortunately sounds like we are SOL. Thanks for contributing.
