The viewport instance shows "Not to scale" instead of it's real scale (differing from the rest of the instances).
2 ANTWORTEN 2
GELÖST
Nachricht 1 von 3
santrod0204
190 Aufrufe, 2 Antworten
Hi everyone,
I'm trying to figure out why the viewport of the first drafting view shown in this post is not showing it's current scale as it may be.
As a reference, I'm leaving a second screenshot where the scale is displayed as intended in the first example. Notice that both examples are in the same file and the viewport family is the same "Viewport 1".
I tried changing it by duplicating the view or changing the viewport family, but the output is always the same. What can it be?
2 ANTWORTEN 2
Nachricht 2 von 3
se.ha
als Antwort auf: santrod0204
Hello @santrod0204
Check if:
se.ha
Dieser Beitrag war hilfreich? Dann könnt ihr diesen Beitrag gerne liken.
Hat dieser Beitrag die Frage erfolgreich beantwortet? Dann klickt bitte auf den Button 'Lösung akzeptieren'.
Nachricht 3 von 3
santrod0204
Wow, didn't know about that option
Thanks! @se.ha
