Is it possible to crop drafting views on sheets?
svalente9GJKH
Message 1 of 11
svalente9GJKH
i am trying to crop out some of my drafting view when placed on sheets but im not seeing a way to do this,  is it in fact at all possible?
Replies (10)
Message 2 of 11
No.  But you can do one of the following:
- add masking regions in the drafting view if the masked area is relatively small, or they may mask adjacent views
- use detail views to draft instead of drafting views
Message 3 of 11
Would you consider a Solid White "Masking" Filled Region on the Sheet?  There is a trick for this, if you are interested.
Message 4 of 11
svalente9GJKH
Sure,  what is the trick?
Message 5 of 11
- draw a detail line on sheet
- make a detail group, keep it on sheet
- place another group instance in a drafting view
- edit group and add filled/masking region, save group
Message 6 of 11
Or you can place a stretchable generic annotation family with a solid filled region to mask anything on sheets.
Message 7 of 11
abataller3W6KX
Community Visitor
Community Visitor
It seem lazy that Autodesk would not provide an option for this feature.
Message 8 of 11
abataller3W6KX
Community Visitor
Community Visitor
I am not trying to throw mud in anybody's face.
But this masking is not a good alternative. It interferes with the adjacent drafting view.
This feature is necessary because some manufacturer provide details that look 3D but they are CAD 2D and the text needs to be accommodated and the scale and the limits of the drawing need to be updated as easily as possible without messing with all filled regions and line work.
Message 9 of 11
Read the entire responses.  Nothing prevents you from using a model view (plan, elevation, section, detail) instead of drafting view then crop it.  using a mask on sheet may not be good for certain cases but useful for others.  Judging a tool because you can't use it personally is narrow minded.
Message 10 of 11
abataller3W6KX
Community Visitor
Community Visitor
Most of us (users in general) do not like to insert dwgs from manufacturers in our model space.
It is considered messy by all standards.  The neat way to do it is to keep the standard details in drafting views.
I am open to options, but that does not sound like a good one.
Message 11 of 11
And most you do not understand why.  Insert DWG in a model view with current view only box checked in makes them drafting linework, not showing in your model or any other views.
