@danezeq wrote:
@barthbradley
Checking "Work Plane-Based" and unchecking "Always Vertical" Still doesn't cause the sign to stick/snap to walls, "Host" field is still Empty.
So, will i HAVE to nest it within a wall faced family? or is there a possible way to change the family itself?
Yes there is. Do exactly what I told you to do in Message #2. I gave you two options. The second one was: check "Work Plane-Based" and uncheck "Always Vertical". Then when you place the family in the Project, pay attention to the Contextual tab. You'll have two placement options to pick from. "Place on Face" and "Place on Work Plane". If you want to host the Family on a Wall Face, then pick "Place on Face".
Work-Plane Based.png(see attached RFA)
Now, if you really need the Family to be strictly a Wall hosted Family and nothing else, then nest the Family into the Generic Model wall based.rft
Do either one of these methods work for you? If so, how about a solution credit? That would work for me.
