Is it possible to add landing at bottom of stair
linkboy
linkboy
Single run assembly stair from L2 to L3. landing can be added at L3 but got error message while adding at L2, which is the bottom of the stair?Capture.PNG
Perhaps lower the stair base and add it as tread.
Are you meaning that you want to begin with a tread? Edit stairs and uncheck "Begin with Riser".
