I have installed Revit 2023 and using it. I wish to do Lighting analysis (Daylighting, Electrical) using Energy Analysis plugin, which is not preinstalled while I installed it. I wish to know if Energy Analysis Tab is a preinstalled one or do I have to install an Add-in?
Thank you for the reply in advance,
Vijesh
Solved by DarrenP. Go to Solution.
its a separate install
you can download from the Desktop App or your Autodesk Account under product updates
DarrenP
Thank you for the reply. But I am unable to find Apps for Revit 2023 in Desktop App. Which app should I use? Request to advise.
Vijesh
I have found it. It was there. It was unable to locate somehow. Thank you.
