I would ask about creating NODE in the custom patterns.
This Revit model is vertical and curved wall but the wall has different height from left corner to right.
My goal:
I would like to make curved wall with diagonal pattern as the above the building image.
My method:
In order to achieve this image, I tired to apply adaptive component after I made custom pattern in the conceptual mass.
Problem:
The node on the boundary is disappeared in conceptual mass after I changed the grid rotation angle in the pattern property,
Every nodes were just find when the angle is 0°C,
but the nodes on the boundary of the pattern has been disappeared after I changed the angle. (As the above Revit Modeling)
Question: Is there any way to create the nodes on the boundary of the pattern?
or In revit,Is there any other way to create that kind of wall as the above building image?
Thanks.
