1st floor and 2nd floor walls stopped connecting
5 ANTWORTEN 5
Nachricht 1 von 6
857 Aufrufe, 5 Antworten
So I'm not quite sure what I have done, but the 1st floor walls and second floor walls have stopped connecting. It was alright before. Screenshot (410).png
The white strip in the middle is the floor
Please let me know how I can get it back to the original form
TIA
5 ANTWORTEN 5
Nachricht 2 von 6
als Antwort auf: Anonymous
Make the walls connected with the Top @ 2nd level, no offset.
Nachricht 3 von 6
And another question, (quite petty :/) so how do i get all the labels (bubbles?) to be on the same side?
so like the basement tag on the right side?
Thank you
Nachricht 4 von 6
Select the basement level and you will see a box at each end. Tick the box to turn on the label and untick to turn off.
Nachricht 5 von 6
@Anonymous: I see from your screenshot, that a floor is separating the two levels (naturally). May I suggest that you wrap that floor with a wall representing a band joist, and then Joining all the walls (Level 1, 2 and band) to remove the "seams".  Basically, model it in Revit, the way it will be built in the field.  Get it?
Nachricht 6 von 6
    Please make sure you did not checked inadvertently "Automatically attach wall to floor". If you did so, the wall has attached to the 1st floor, regardless of the correct height settings.  In order to undo it, click the wall and "Detach top". It will resume to correct height.
