invisible drawing
invisible drawing
Message 1 of 12
invisible drawing
Good evening, please see attached image for reference.
I am trying to insert a drawing which has a linked Revit model into a sheet and the only thing I can see is this blue circle with an X inside. I zoom in to find the drawing, sometimes I find it and sometimes I cannot.
any suggestions please?
thank you
Replies (11)
Message 2 of 12
ennujozlagam
hello, go to properties > visibilty/ graphics overrrides > model categories > scoll down until you see site > select + sign > untick project base point and survey point > apply/ok > zoom to fit > then you will be able to see your drawings. check also your phasing in properties box. discipline set to coordination. thanks
Message 3 of 12
Thank you for your response, I followed all the steps and the drawing is still invisible. it appears in the project browser as it was already been placed in the sheet but is not there.
Thank you
Message 4 of 12
Corsten.Au
Link Revit in Plan
go to VG, and use " by linked view"
move the link to correct location and crop the view properly before
placing on the sheet...
Best luck
linked viewlinked view
Corsten
Building Designer
Message 5 of 12
ennujozlagam
hello, in addition you can also try this VG > Revit links > custom . thanks
Message 6 of 12
I'm totally confused.
You are trying to do what with what?
Maybe are you trying to Insert Sheets from a File?
 https://knowledge.autodesk.com/support/revit-lt/learn-explore/caas/CloudHelp/cloudhelp/2017/ENU/Revi...
Message 7 of 12
good morning, I am dragging the view from the project browser into the sheet and it does not show up in the sheet. the views contain linked Revit models.
I am going to follow your last e-mail and see what happens
thank you
Message 8 of 12
brettgatti
If you open any of the views that you are attempting to drag onto sheets, do you see any data?
Message 9 of 12
Thank you fro your response.
this is what I get when I hit VG: please see attached image
thank you
Message 10 of 12
Yes, it looks like everything is locked down by a View Template.  This would have nothing to do with Views showing differently on sheets though. The View is what it is.  It should look the same on the sheet as it does in the View itself.
Message 11 of 12
Hi Mr. Bradley
Thank you for your time.
I have a drawing -which is totally visible on the sheet- with the same view template of the ones which don't show up.
Thank you
Message 12 of 12
yes, I figured that out, it was a view tem[plete issue.
T H AN KOUUUUUUU
