Interoperbility tools, how does it work? .xml file
Andreasdraxl
Andreasdraxl
Hello Reviter,
How does it work with the interoperbility-tools!?
i want to IFCclassify my elements, but i have no default xml-list to modify.
Can anybody give me an advice?
where can i find this .xml and how can i modify it?
KR
Andreas
Mit freundlichen Grüßen
Andreas
Revit 2022
Dynamo 2.12.0.
Navisworks 2022>IFC4
RDAOU
@Andreasdraxl
By default if not moved to another location they can be found in the following directory
C:\Program Files (x86)\Autodesk\BIT\2022\Resources
More on the how to you can find on the following links
https://www.youtube.com/watch?v=Ya6J4Iqf6lo
https://interoperability.autodesk.com/classificationmanager.php
https://bim-me-up.com/klassifizierungsmanager-fur-revit/
Andreasdraxl
Ok i found it but there is no .xml regarding IFC classification?
Or have i to use the Classification Manager Database Custom? and how to costumise it?
Does the ifcClassification also work for the TypeEnumeration ?
f.e.:  IfcFurniture.SHELF ... CHAIR ... TABLE ...
I checked it ! it does not work! how can the tool say "i do it" and finally nothing happend!
Andreas
Revit 2022
Dynamo 2.12.0.
RDAOU
@Andreasdraxl wrote:
The folder is emty! in my case!
Can you publish this XML? or do you have a download-link?
KR
Andreas
@Andreasdraxl
If the files are missing then they have been either moved or it is a bad installation...best would be to remove the BIT tool and reinstall
the database is an xlsx not xml...It is also attached below...Link to the database download should be also found in previous reply and link also highlighted below
RDAOU
@Andreasdraxl
You have to stop re-editing your posts and questions.
One cannot post 10 replies to 1 post while you continuously keep changing the original question after implementing the given replies!! I believe I have already answered your original question. Hence, I have nothing further to add to this discussion.
  1. You have cross posted your questions on several boards of this forum. please do not do that
  2. You have 15 open posts since  13.07.2020  including this one
    • You should close out old posts.
    • Should you have new question post them under a new thread.
    • If none of the replies to your post answered your question, state so in discussion
    • (optional: should you be generous and kind to help other users, provide info on how you solved the issue if you did actually end up solving it
...and in addition to what @RDAOU scolded you about, you should never wear white after Labor Day.  Don't know why. I just know it's a fopaux.
Andreasdraxl
Thank you, i got an answer from autodesk! inspite of all tools. Autodesk Revit is not supporting the TypeEnumuration of IFC4 ...
KR
Andreas
Andreas
Revit 2022
Dynamo 2.12.0.
