Interoperability regarding gbXML
Hi all,
As a new user and explorer of Revit, I'm studying it's Interoperability for my Thesis.
My simple question is, what kind of gbXML file is Revit able to Import? And from what kind of softwares? Also, would someone have any file that could upload here, so I can see how it works? I know Revit, in that case, should not be a viewer for other softwares geometry.
My Thesis is related to the software interoperability regarding Energy Simulations.
Thank you
Lance.Coffey
Autodesk Support
Autodesk Support
Thank you for the question @Anonymous !
I’m seeing that the Import gbXML command (Insert Ribbon Tab -> Import Ribbon Panel) is associated with the following help topic:
Import a Loads Analysis from a gbXML File
The Related Information section of the help topic above has a link to the gbXML Schema Support (version 0.37). Is this the information you are looking for regarding gbXML file support??
Regarding an example gbXML file, you could start with one of the Revit Sample Projects, and export to gbXML.
Lance Coffey
Technical Support Specialist
Hi @Lance.Coffey, thank you for the answers so far!
I've read the information on those links (gbXML Schema Support (version 0.37) and Import a Loads Analysis from a gbXML File) already and it helped me by now.
I'm producing my thesis on Autodesk Revit Interoperability, and trying to figure a way to import gbXML, but couldn't find a sample or file to make the process of importation (even on that link: Sample Projects)
Thank you so far.
