interior wall footing.
money2312
Message 1 of 10
money2312
can some give me step by step instructions on how to create interior wall footing that reacts like slab edges. Or tell me where I can find the info. I'm using Revit Lt 2017
Replies (9)
Message 2 of 10
Don't LT have Wall Footing tool?
You can build another fatter and shorter wall below the interior wall, or simply copy paste aligned to the foundation level, change wall type and height.  You can even build a stacked wall with the footing built-in.
Message 3 of 10
loboarch
I am not clear exactly what behavior you are looking for on the footing?  Can you add some additional information so i can understand what the goal is.
Jeff Hanson
Principal Content Experience Designer
Revit Help |
Message 4 of 10
money2312
the behavior I'm looking for is the footing snap to the floor slab like floor edges do.  Is that possible ?
Message 5 of 10
money2312
how do put the sloped edges that represent each side of the footing?
Message 6 of 10
You can create a reveal with triangular profile to chamfer off the bottom of the wall footing.  Or create a sweep with the profile of the footing and draw it along the bottom of the interior walls.
Message 7 of 10
loboarch
The snapping behavior would follow the wall footing. If you select the wall footing tool from the Structure tab of the ribbon a wall foundation family will be placed at the lowest edge of the wall and snap to it.
As for the shape, a foundation is a system family and is rectangular in shape. there is no way to alter that. You would need to either use  voids to cut the foundation or make a loadable family to be used as a wall foundation.
Jeff Hanson
Revit Help |
Message 8 of 10
So LT has Structural Wall footing tool?  I asked the question right off the bat but didn't get any answer.
Message 9 of 10
loboarch
It does. I had to open LT to make sure.
Jeff Hanson
Revit Help |
Message 10 of 10
Since LT has wall footing tool then try the attached file.
