Interior Elevation symbol is not displaying on plan
tstewart
Message 1 of 10
tstewart
Interior Elevation symbols are not displaying on plan. How to display an Elevation Symbol in plan (they're displayed under Reveal Hidden Elements)?
Accepted solutions (3)
Replies (9)
Message 2 of 10
mhiserZFHXS
Check your visibility/graphics overrides and your view template.
Message 3 of 10
jay_colc
So i am assuming that in Viability Graphics and Filters they are not being hidden intentionally or set as such in a View Template!
Make sure the plan view and the elevation views are under the same phase.
Also make sure the view has a scale larger than the elevation's "Hide at scales coarser than:" limit.
Finally is it just a glitch? If you create a new floor plan do they appear?
Jay Colcombe
Autodesk Certified Instructor
Message 4 of 10
tstewart
I've checked the VG Overrides and do not see Elevation or Symbols listed. Where is the View Template?
TS
Message 5 of 10
tstewart
TS
Message 6 of 10
syman2000
Since you click on the reveal hidden, check and see if you can unhide it using the unhide element or unhide category
Message 7 of 10
tstewart
Thank you for that response. It worked!
Message 8 of 10
tstewart
Now, if I can only make them smaller (<1/2") and remove the Elevation text near the arrowhead?
Message 9 of 10
mhiserZFHXS
Elevation tags are annotations, so they stay the same size no matter what scale your view is at. What text near the arrowhead are you referring to?
Sounds like you just need to create some custom elevation markers.
Message 10 of 10
tstewart
The Elevation marker has the name of the view on it (see attached), so how to turn off?
