Interior Elevation option not showing only exterior elevation available
jroman284M2Z
jroman284M2Z
Community Visitor
Community Visitor
When I go to view and select elevation, it only shows exterior elevation. There is no Interior Elevation option; only exterior elevation is available.
nozci
I think It is the template you are using.  Have a look:
Solved: Elevations - Building (exterior) or interior - Autodesk Community - Revit Products
RC_RVT
Just duplicate the elevation type and create your own interior elevation. From here you can add a view template to it if you want.
(view in My Videos)
