Insulation hatch pattern
lorena_dantas
Message 1 of 9
lorena_dantas
I've created an insulation hatch pattern with pyRevit. The problem is that is doesn't align at the begging of my insulation wall layer. What can I do ? I've select the option "align to element", and I've dimensioned the size of the motif (pattern) accordingly to the insulation thickness.
Replies (8)
Message 2 of 9
Tom_Kunsman
Out of curiosity, why not just use the insulation tool that Revit has?
Message 3 of 9
lorena_dantas
In the company, they use a different BIM software, and I'm in the process of introducing Revit. They prefer to maintain the graphics in a manner consistent with what they're used to.
Message 4 of 9
I totally agree with @Tom_Kunsman on this one. Use the in-built Insulation tool on the Annotation Tab. It couldn't be any simpler.  Why re-invent the wheel?
Message 5 of 9
BTW, I wouldn't add the batt pattern to the Material Graphics. Is that what you are thinking of doing?
Message 6 of 9
Message 7 of 9
Mike.FORM
Another issue making the insulation a hatch is that cut patterns can only be drafting patterns (not model patterns) and drafting patterns will stay the same scale on a sheet no matter what the view scale is and thus if your scale is 1:100 it might look fine but if your view is 1:75 or 1:50 the insulation scale will remain the same so it would look like 2 layers of insulation at 1:50.
This means you would need a different scaled hatch for every view scale.
As others have said the insulation tool is the best and easiest way to accomplish your task.
Message 8 of 9
Adding batt insulation hatch as a cut pattern to materials is a losing battle.  It will fail one way or another.  Sorry to sound unencouraging, but it is so you won't be wasting time trying to make it work.
Message 9 of 9
lorena_dantas
Yes, it's.
