Hi Everyone,
I have 2 models that are almost identical, the second model is copied from the first so they are positioned the same.
I want to copy some items across that I added in the second model, is there a simple way to drop them in, sort of like in Autocad when you copy and paste to the same co-ordinates and it drops in to the correct location.
Regards
Phil
Gelöst! Gehe zur Lösung
Gelöst von jay_colcombe. Gehe zur Lösung
You can use the Copy to Clipboard options in the Revit Modify Panel and Paste Aligned to the current View
You could also link in the model and use Copy/Monitor from the Collaborate Tab to achieve similar results
