Installitation incomplete. Some products failed to install
I have tried multiple times to install revit student edition. I have turned my firewall off but to no avail. Everything downloads but everything fails to install. Any ideas?
2015/12/26:19:30:41 Ethan ETHAN-PC === Setup started on ETHAN-PC by Ethan ===
2015/12/26:19:30:41 Ethan ETHAN-PC Path_Length: 155
2015/12/26:19:30:41 Ethan ETHAN-PC Current Directory C:\Program Files\Autodesk\Revit Content 2016\Setup
2015/12/26:19:30:41 Ethan ETHAN-PC Launch
2015/12/26:19:30:41 Ethan ETHAN-PC CommandLine /P {941030D0-1600-0410-0000-818BB38A95FC} /M RCL /LANG en-US
2015/12/26:19:30:41 Ethan ETHAN-PC Current Directory C:\Users\Ethan\AppData\Local\Temp\_AI13BB.tmp
2015/12/26:19:30:50 Ethan ETHAN-PC === Setup ended ===
2015/12/26:19:30:44 Ethan ETHAN-PC === Setup started on ETHAN-PC by Ethan ===
2015/12/26:19:30:44 Ethan ETHAN-PC Path_Length: 155
2015/12/26:19:30:44 Ethan ETHAN-PC Current Directory C:\Users\Ethan\AppData\Local\Temp\_AI13BB.tmp
2015/12/26:19:30:44 Ethan ETHAN-PC Launch
2015/12/26:19:30:51 Ethan ETHAN-PC PageOpen MaintenanceDialog
2015/12/26:19:30:59 Ethan ETHAN-PC [Error: 1056] An instance of the service is already running.
2015/12/26:19:30:59 Ethan ETHAN-PC === Setup ended ===
2015/12/26:19:34:41 Ethan ETHAN-PC === Setup started on ETHAN-PC by Ethan ===
2015/12/26:19:34:41 Ethan ETHAN-PC Path_Length: 155
2015/12/26:19:34:41 Ethan ETHAN-PC Current Directory C:\Program Files\Autodesk\Revit 2016\Setup
2015/12/26:19:34:41 Ethan ETHAN-PC Launch
2015/12/26:19:34:41 Ethan ETHAN-PC CommandLine /P {7346B4A0-1600-0510-0000-705C0D862004} /M RVT /LANG en-US
2015/12/26:19:34:41 Ethan ETHAN-PC Current Directory C:\Users\Ethan\AppData\Local\Temp\_AIBD0C.tmp
2015/12/26:19:34:44 Ethan ETHAN-PC === Setup ended ===
2015/12/26:19:34:43 Ethan ETHAN-PC === Setup started on ETHAN-PC by Ethan ===
2015/12/26:19:34:43 Ethan ETHAN-PC Path_Length: 155
2015/12/26:19:34:43 Ethan ETHAN-PC Current Directory C:\Users\Ethan\AppData\Local\Temp\_AIBD0C.tmp
2015/12/26:19:34:43 Ethan ETHAN-PC Launch
2015/12/26:19:34:44 Ethan ETHAN-PC PageOpen MaintenanceDialog
2015/12/26:19:34:47 Ethan ETHAN-PC PageOpen MaintVerifyReadyDialog
2015/12/26:19:34:50 Ethan ETHAN-PC PageOpen FullProgressDialog
2015/12/26:19:34:52 Ethan ETHAN-PC Installing Autodesk® Revit® 2016: REMOVE=ALL INSTALLDIR="C:\Program Files\Autodesk\Revit 2016\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2015/12/26:19:43:59 Ethan ETHAN-PC Uninstall Autodesk® Revit® 2016 Succeeded
2015/12/26:19:43:59 Ethan ETHAN-PC PageOpen MaintCompleteDialog
2015/12/26:19:44:22 Ethan ETHAN-PC === Setup ended ===
2015/12/26:19:48:17 Ethan ETHAN-PC === Setup started on ETHAN-PC by Ethan ===
2015/12/26:19:48:17 Ethan ETHAN-PC Path_Length: 155
2015/12/26:19:48:17 Ethan ETHAN-PC Current Directory C:\Program Files\Autodesk\Revit Content 2016\Setup
2015/12/26:19:48:17 Ethan ETHAN-PC Launch
2015/12/26:19:48:17 Ethan ETHAN-PC CommandLine /P {941030D0-1600-0410-0000-818BB38A95FC} /M RCL /LANG en-US
2015/12/26:19:48:17 Ethan ETHAN-PC Current Directory C:\Users\Ethan\AppData\Local\Temp\_AI333B.tmp
2015/12/26:19:48:19 Ethan ETHAN-PC === Setup ended ===
2015/12/26:19:48:18 Ethan ETHAN-PC === Setup started on ETHAN-PC by Ethan ===
2015/12/26:19:48:18 Ethan ETHAN-PC Path_Length: 155
2015/12/26:19:48:18 Ethan ETHAN-PC Current Directory C:\Users\Ethan\AppData\Local\Temp\_AI333B.tmp
2015/12/26:19:48:18 Ethan ETHAN-PC Launch
2015/12/26:19:48:19 Ethan ETHAN-PC PageOpen MaintenanceDialog
2015/12/26:19:48:21 Ethan ETHAN-PC PageOpen MaintVerifyReadyDialog
2015/12/26:19:48:22 Ethan ETHAN-PC PageOpen FullProgressDialog
2015/12/26:19:48:22 Ethan ETHAN-PC Installing Autodesk® Revit® Content Libraries 2016: REMOVE=ALL INSTALLDIR="C:\Program Files\Autodesk\Revit Content 2016\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2015/12/26:19:59:44 Ethan ETHAN-PC Uninstall Autodesk® Revit® Content Libraries 2016 Succeeded
2015/12/26:19:59:44 Ethan ETHAN-PC PageOpen MaintCompleteDialog
2015/12/26:19:59:52 Ethan ETHAN-PC === Setup ended ===
2015/12/26:20:10:48 Ethan ETHAN-PC === Setup started on ETHAN-PC by Ethan ===
2015/12/26:20:10:48 Ethan ETHAN-PC Path_Length: 155
2015/12/26:20:10:48 Ethan ETHAN-PC Current Directory C:\Autodesk\Autodesk_Revit_2016_English_Win_64bit_SP2_wi_en-US
2015/12/26:20:10:48 Ethan ETHAN-PC Launch
2015/12/26:20:10:48 Ethan ETHAN-PC CommandLine /PK 829H1 /SN 900-49666621 /akamai /sid SESSION_ID /skipEULA /student /url "http://edutrial.autodesk.com/NET16SWDLD/2016/RVT/WI/Autodesk_Revit_2016_English_Win_64bit_SP2_wi_en-...
2015/12/26:20:10:48 Ethan ETHAN-PC Current Directory C:\Users\Ethan\AppData\Local\Temp\_AIF7FF.tmp
2015/12/26:20:11:16 Ethan ETHAN-PC === Setup ended ===
2015/12/26:20:10:49 Ethan ETHAN-PC === Setup started on ETHAN-PC by Ethan ===
2015/12/26:20:10:49 Ethan ETHAN-PC Path_Length: 155
2015/12/26:20:10:49 Ethan ETHAN-PC Current Directory C:\Users\Ethan\AppData\Local\Temp\_AIF7FF.tmp
2015/12/26:20:10:49 Ethan ETHAN-PC Launch
2015/12/26:20:10:50 Ethan ETHAN-PC Download Play SETUPMARKER http://edutrial.autodesk.com/NET16SWDLD/2016/RVT/WI/{3D6F0F4C-42BF-4584-B497-24782CAA8535}/SETUPMARK...
2015/12/26:20:10:51 Ethan ETHAN-PC Download Complete SETUPMARKER http://edutrial.autodesk.com/NET16SWDLD/2016/RVT/WI/{3D6F0F4C-42BF-4584-B497-24782CAA8535}/SETUPMARK...
2015/12/26:20:10:51 Ethan ETHAN-PC Download Play SETUP_CONFIG http://edutrial.autodesk.com/NET16SWDLD/2016/RVT/WI/{3D6F0F4C-42BF-4584-B497-24782CAA8535}/SETUP_x64...
2015/12/26:20:11:15 Ethan ETHAN-PC Download Complete SETUP_CONFIG http://edutrial.autodesk.com/NET16SWDLD/2016/RVT/WI/{3D6F0F4C-42BF-4584-B497-24782CAA8535}/SETUP_x64...
2015/12/26:20:11:16 Ethan ETHAN-PC Install CustomCallback Info Invoking custom callback for details: [SETUP] CB_FUNC=CustomCallbackRevitOSVersionCheck CB_SOURCE=C:\Users\Ethan\AppData\Local\Temp\_AIF7FF.tmp\Setup\RevitSetup.dll
2015/12/26:20:11:16 Ethan ETHAN-PC Install CustomCallback Info Custom callback response: Status=0 SUCCECSS Title= Message= URLTitle= URLLink=
2015/12/26:20:11:17 Ethan ETHAN-PC PageOpen LaunchDialog
2015/12/26:20:11:25 Ethan ETHAN-PC Install CustomCallback Info Invoking custom callback for details: [RCL] CB_FUNC=CustomCallbackRevitContentWarning CB_SOURCE=C:\Users\Ethan\AppData\Local\Temp\_AIF7FF.tmp\Setup\RevitSetup.dll
2015/12/26:20:11:25 Ethan ETHAN-PC Install CustomCallback Info Custom callback response: Status=1 INFO Title= Message=Deselecting the content installation will affect critical settings in Autodesk® Revit® 2016. URLTitle= URLLink=
2015/12/26:20:12:34 Ethan ETHAN-PC PageOpen LicenseDialog
2015/12/26:20:12:34 Ethan ETHAN-PC PageOpen ProductInfoDialog
2015/12/26:20:12:34 Ethan ETHAN-PC PageOpen ProductSelectionDialog2
2015/12/26:20:13:18 Ethan ETHAN-PC PageOpen FullProgressDialog
2015/12/26:20:13:18 Ethan ETHAN-PC Installing FaroSDK: ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk Revit 2016" SETUP_PACKAGECODE={7346B4A0-1600-0510-0000-705C0D862004} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=";;;;" ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk Revit 2016" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2015/12/26:20:13:32 Ethan ETHAN-PC Install FaroSDK Succeeded
2015/12/26:20:13:33 Ethan ETHAN-PC Download Play STARTMARKER http://edutrial.autodesk.com/NET16SWDLD/2016/RVT/WI/{3D6F0F4C-42BF-4584-B497-24782CAA8535}/STARTMARK...
2015/12/26:20:13:33 Ethan ETHAN-PC Download Complete STARTMARKER http://edutrial.autodesk.com/NET16SWDLD/2016/RVT/WI/{3D6F0F4C-42BF-4584-B497-24782CAA8535}/STARTMARK...
2015/12/26:20:13:33 Ethan ETHAN-PC Download Play RCL http://edutrial.autodesk.com/NET16SWDLD/2016/RVT/WI/{3D6F0F4C-42BF-4584-B497-24782CAA8535}/RCL_x64.t...
2015/12/26:20:13:42 Ethan ETHAN-PC Download Complete RCL http://edutrial.autodesk.com/NET16SWDLD/2016/RVT/WI/{3D6F0F4C-42BF-4584-B497-24782CAA8535}/RCL_x64.t...
2015/12/26:20:13:42 Ethan ETHAN-PC Installing Autodesk® Revit® Content Libraries 2016: TRANSFORMS=":en-us.mst;C:\Users\Ethan\AppData\Local\Temp\_AIF7FF.tmp\x64\RCL\RCL-standalone.mst" ADSK_EULA_STATUS=#1 ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk Revit 2016" INSTALLDIR="C:\Program Files\Autodesk\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2015/12/26:20:29:53 Ethan ETHAN-PC Install Autodesk® Revit® Content Libraries 2016 Succeeded
2015/12/26:20:29:53 Ethan ETHAN-PC Download Play RVT http://edutrial.autodesk.com/NET16SWDLD/2016/RVT/WI/{3D6F0F4C-42BF-4584-B497-24782CAA8535}/RVT_x64.t...
2015/12/26:20:38:05 Ethan ETHAN-PC Download Complete RVT http://edutrial.autodesk.com/NET16SWDLD/2016/RVT/WI/{3D6F0F4C-42BF-4584-B497-24782CAA8535}/RVT_x64.t...
2015/12/26:20:38:06 Ethan ETHAN-PC Installing Autodesk® Revit® 2016: TRANSFORMS=":en-us.mst;:all.mst;C:\Users\Ethan\AppData\Local\Temp\_AIF7FF.tmp\x64\RVT\RVT-standalone.mst" ADSK_EULA_STATUS=#1 ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk Revit 2016" INSTALLDIR="C:\Program Files\Autodesk\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2015/12/26:20:41:56 Ethan ETHAN-PC Install Autodesk® Revit® 2016 Succeeded
2015/12/26:20:41:56 Ethan ETHAN-PC Installing Autodesk® BIM 360™ Add-in for Revit® 2016: ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk Revit 2016" SETUP_PACKAGECODE={7346B4A0-1600-0510-0000-705C0D862004} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=";;;;" ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk Revit 2016" INSTALLDIR="C:\Program Files\Autodesk\BIM360GlueAddins\Revit2016Addin\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2015/12/26:20:42:00 Ethan ETHAN-PC Install Autodesk® BIM 360™ Add-in for Revit® 2016 Succeeded
2015/12/26:20:42:01 Ethan ETHAN-PC Download Play CMILM2016 http://edutrial.autodesk.com/NET16SWDLD/2016/RVT/WI/{3D6F0F4C-42BF-4584-B497-24782CAA8535}/CMILM2016...
2015/12/26:20:46:21 Ethan ETHAN-PC Download Aborted CMILM2016 http://edutrial.autodesk.com/NET16SWDLD/2016/RVT/WI/{3D6F0F4C-42BF-4584-B497-24782CAA8535}/CMILM2016...
2015/12/26:20:46:21 Ethan ETHAN-PC Install Autodesk Material Library 2016 - Medium Image Library Failed Download Failed, Installation aborted, Result=1603
2015/12/26:20:46:23 Ethan ETHAN-PC Rollback Autodesk® BIM 360™ Add-in for Revit® 2016 Succeeded
2015/12/26:20:51:22 Ethan ETHAN-PC Rollback Autodesk® Revit® 2016 Succeeded
2015/12/26:20:53:54 Ethan ETHAN-PC Rollback Autodesk® Revit® Content Libraries 2016 Succeeded
2015/12/26:20:53:58 Ethan ETHAN-PC Rollback FaroSDK Succeeded
2015/12/26:20:53:58 Ethan ETHAN-PC PageOpen InstallCompleteDialog
2015/12/26:21:05:55 Ethan ETHAN-PC === Setup ended ===
2015/12/26:21:13:57 Ethan ETHAN-PC === Setup started on ETHAN-PC by Ethan ===
2015/12/26:21:13:57 Ethan ETHAN-PC Path_Length: 155
2015/12/26:21:13:57 Ethan ETHAN-PC Current Directory C:\Autodesk\Autodesk_Revit_2016_English_Win_64bit_SP2_wi_en-US
2015/12/26:21:13:57 Ethan ETHAN-PC Launch
2015/12/26:21:13:57 Ethan ETHAN-PC CommandLine /URL "http://edutrial.autodesk.com/NET16SWDLD/2016/RVT/WI/Autodesk_Revit_2016_English_Win_64bit_SP2_wi_en-... /skipPI /SN 900-49666621 /PK 829H1 /akamai
2015/12/26:21:13:57 Ethan ETHAN-PC Current Directory C:\Users\Ethan\AppData\Local\Temp\_AI9D55.tmp
2015/12/26:21:14:29 Ethan ETHAN-PC === Setup ended ===
2015/12/26:21:14:04 Ethan ETHAN-PC === Setup started on ETHAN-PC by Ethan ===
2015/12/26:21:14:04 Ethan ETHAN-PC Path_Length: 155
2015/12/26:21:14:04 Ethan ETHAN-PC Current Directory C:\Users\Ethan\AppData\Local\Temp\_AI9D55.tmp
2015/12/26:21:14:04 Ethan ETHAN-PC Launch
2015/12/26:21:14:27 Ethan ETHAN-PC Download Skipped SETUPMARKER http://edutrial.autodesk.com/NET16SWDLD/2016/RVT/WI/{3D6F0F4C-42BF-4584-B497-24782CAA8535}/SETUPMARK...
2015/12/26:21:14:27 Ethan ETHAN-PC Download Skipped SETUP_CONFIG http://edutrial.autodesk.com/NET16SWDLD/2016/RVT/WI/{3D6F0F4C-42BF-4584-B497-24782CAA8535}/SETUP_x64...
2015/12/26:21:14:28 Ethan ETHAN-PC Install CustomCallback Info Invoking custom callback for details: [SETUP] CB_FUNC=CustomCallbackRevitOSVersionCheck CB_SOURCE=C:\Users\Ethan\AppData\Local\Temp\_AI9D55.tmp\Setup\RevitSetup.dll
2015/12/26:21:14:28 Ethan ETHAN-PC Install CustomCallback Info Custom callback response: Status=0 SUCCECSS Title= Message= URLTitle= URLLink=
2015/12/26:21:14:30 Ethan ETHAN-PC PageOpen LaunchDialog
2015/12/26:21:14:48 Ethan ETHAN-PC Install CustomCallback Info Invoking custom callback for details: [RCL] CB_FUNC=CustomCallbackRevitContentWarning CB_SOURCE=C:\Users\Ethan\AppData\Local\Temp\_AI9D55.tmp\Setup\RevitSetup.dll
2015/12/26:21:14:48 Ethan ETHAN-PC Install CustomCallback Info Custom callback response: Status=1 INFO Title= Message=Deselecting the content installation will affect critical settings in Autodesk® Revit® 2016. URLTitle= URLLink=
2015/12/26:21:15:59 Ethan ETHAN-PC PageOpen LicenseDialog
2015/12/26:21:16:04 Ethan ETHAN-PC PageOpen ProductInfoDialog
2015/12/26:21:16:04 Ethan ETHAN-PC PageOpen ProductSelectionDialog2
2015/12/26:21:16:19 Ethan ETHAN-PC PageOpen FullProgressDialog
2015/12/26:21:16:20 Ethan ETHAN-PC Installing FaroSDK: ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk Revit 2016" SETUP_PACKAGECODE={7346B4A0-1600-0510-0000-705C0D862004} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=";;;;" ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk Revit 2016" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2015/12/26:21:16:45 Ethan ETHAN-PC Install FaroSDK Succeeded
2015/12/26:21:16:46 Ethan ETHAN-PC Download Play STARTMARKER http://edutrial.autodesk.com/NET16SWDLD/2016/RVT/WI/{3D6F0F4C-42BF-4584-B497-24782CAA8535}/STARTMARK...
2015/12/26:21:16:47 Ethan ETHAN-PC Download Complete STARTMARKER http://edutrial.autodesk.com/NET16SWDLD/2016/RVT/WI/{3D6F0F4C-42BF-4584-B497-24782CAA8535}/STARTMARK...
2015/12/26:21:16:47 Ethan ETHAN-PC Download Skipped RCL http://edutrial.autodesk.com/NET16SWDLD/2016/RVT/WI/{3D6F0F4C-42BF-4584-B497-24782CAA8535}/RCL_x64.t...
2015/12/26:21:16:48 Ethan ETHAN-PC Installing Autodesk® Revit® Content Libraries 2016: TRANSFORMS=":en-us.mst;C:\Users\Ethan\AppData\Local\Temp\_AI9D55.tmp\x64\RCL\RCL-standalone.mst" ADSK_EULA_STATUS=#1 ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk Revit 2016" INSTALLDIR="C:\Program Files\Autodesk\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2015/12/26:21:39:59 Ethan ETHAN-PC Download Play CANCELMARKER http://edutrial.autodesk.com/NET16SWDLD/2016/RVT/WI/{3D6F0F4C-42BF-4584-B497-24782CAA8535}/CANCELMAR...
2015/12/26:21:40:00 Ethan ETHAN-PC Download Complete CANCELMARKER http://edutrial.autodesk.com/NET16SWDLD/2016/RVT/WI/{3D6F0F4C-42BF-4584-B497-24782CAA8535}/CANCELMAR...
2015/12/26:21:40:00 Ethan ETHAN-PC Install Autodesk® Revit® Content Libraries 2016 Failed Failure is ignored, Result=1602
2015/12/26:21:40:00 Ethan ETHAN-PC PageOpen InstallCompleteDialog
2015/12/26:21:40:43 Ethan ETHAN-PC === Setup ended ===
2015/12/26:21:45:03 Ethan ETHAN-PC === Setup started on ETHAN-PC by Ethan ===
2015/12/26:21:45:03 Ethan ETHAN-PC Path_Length: 155
2015/12/26:21:45:03 Ethan ETHAN-PC Current Directory C:\Autodesk\Autodesk_Revit_2016_English_Win_64bit_SP2_wi_en-US
2015/12/26:21:45:03 Ethan ETHAN-PC Launch
2015/12/26:21:45:03 Ethan ETHAN-PC CommandLine /PK 829H1 /SN 900-49666621 /akamai /sid SESSION_ID /skipEULA /student /url "http://edutrial.autodesk.com/NET16SWDLD/2016/RVT/WI/Autodesk_Revit_2016_English_Win_64bit_SP2_wi_en-...
2015/12/26:21:45:03 Ethan ETHAN-PC Current Directory C:\Users\Ethan\AppData\Local\Temp\_AI2EDF.tmp
2015/12/26:21:45:07 Ethan ETHAN-PC === Setup ended ===
2015/12/26:21:45:04 Ethan ETHAN-PC === Setup started on ETHAN-PC by Ethan ===
2015/12/26:21:45:04 Ethan ETHAN-PC Path_Length: 155
2015/12/26:21:45:04 Ethan ETHAN-PC Current Directory C:\Users\Ethan\AppData\Local\Temp\_AI2EDF.tmp
2015/12/26:21:45:04 Ethan ETHAN-PC Launch
2015/12/26:21:45:05 Ethan ETHAN-PC Download Skipped SETUPMARKER http://edutrial.autodesk.com/NET16SWDLD/2016/RVT/WI/{3D6F0F4C-42BF-4584-B497-24782CAA8535}/SETUPMARK...
2015/12/26:21:45:05 Ethan ETHAN-PC Download Skipped SETUP_CONFIG http://edutrial.autodesk.com/NET16SWDLD/2016/RVT/WI/{3D6F0F4C-42BF-4584-B497-24782CAA8535}/SETUP_x64...
2015/12/26:21:45:06 Ethan ETHAN-PC Install CustomCallback Info Invoking custom callback for details: [SETUP] CB_FUNC=CustomCallbackRevitOSVersionCheck CB_SOURCE=C:\Users\Ethan\AppData\Local\Temp\_AI2EDF.tmp\Setup\RevitSetup.dll
2015/12/26:21:45:06 Ethan ETHAN-PC Install CustomCallback Info Custom callback response: Status=0 SUCCECSS Title= Message= URLTitle= URLLink=
2015/12/26:21:45:07 Ethan ETHAN-PC PageOpen LaunchDialog
2015/12/26:21:46:19 Ethan ETHAN-PC PageOpen LicenseDialog
2015/12/26:21:46:19 Ethan ETHAN-PC PageOpen ProductSelectionDialog2
2015/12/26:21:46:29 Ethan ETHAN-PC PageOpen LicenseDialog
2015/12/26:21:46:29 Ethan ETHAN-PC PageOpen LaunchDialog
2015/12/26:21:46:34 Ethan ETHAN-PC Install CustomCallback Info Invoking custom callback for details: [RCL] CB_FUNC=CustomCallbackRevitContentWarning CB_SOURCE=C:\Users\Ethan\AppData\Local\Temp\_AI2EDF.tmp\Setup\RevitSetup.dll
2015/12/26:21:46:34 Ethan ETHAN-PC Install CustomCallback Info Custom callback response: Status=1 INFO Title= Message=Deselecting the content installation will affect critical settings in Autodesk® Revit® 2016. URLTitle= URLLink=
2015/12/26:21:47:19 Ethan ETHAN-PC PageOpen LicenseDialog
2015/12/26:21:47:19 Ethan ETHAN-PC PageOpen ProductInfoDialog
2015/12/26:21:47:19 Ethan ETHAN-PC PageOpen ProductSelectionDialog2
2015/12/26:21:48:44 Ethan ETHAN-PC PageOpen FullProgressDialog
2015/12/26:21:48:44 Ethan ETHAN-PC Download Play STARTMARKER http://edutrial.autodesk.com/NET16SWDLD/2016/RVT/WI/{3D6F0F4C-42BF-4584-B497-24782CAA8535}/STARTMARK...
2015/12/26:21:48:45 Ethan ETHAN-PC Download Complete STARTMARKER http://edutrial.autodesk.com/NET16SWDLD/2016/RVT/WI/{3D6F0F4C-42BF-4584-B497-24782CAA8535}/STARTMARK...
2015/12/26:21:48:45 Ethan ETHAN-PC Download Skipped RCL http://edutrial.autodesk.com/NET16SWDLD/2016/RVT/WI/{3D6F0F4C-42BF-4584-B497-24782CAA8535}/RCL_x64.t...
2015/12/26:21:48:45 Ethan ETHAN-PC Installing Autodesk® Revit® Content Libraries 2016: TRANSFORMS=":en-us.mst;C:\Users\Ethan\AppData\Local\Temp\_AI2EDF.tmp\x64\RCL\RCL-standalone.mst" ADSK_EULA_STATUS=#1 ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk Revit 2016" INSTALLDIR="C:\Program Files\Autodesk\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2015/12/26:22:08:56 Ethan ETHAN-PC Install Autodesk® Revit® Content Libraries 2016 Succeeded
2015/12/26:22:08:57 Ethan ETHAN-PC Download Skipped RVT http://edutrial.autodesk.com/NET16SWDLD/2016/RVT/WI/{3D6F0F4C-42BF-4584-B497-24782CAA8535}/RVT_x64.t...
2015/12/26:22:08:59 Ethan ETHAN-PC Installing Autodesk® Revit® 2016: TRANSFORMS=":en-us.mst;:all.mst;C:\Users\Ethan\AppData\Local\Temp\_AI2EDF.tmp\x64\RVT\RVT-standalone.mst" ADSK_EULA_STATUS=#1 ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk Revit 2016" INSTALLDIR="C:\Program Files\Autodesk\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2015/12/26:22:19:05 Ethan ETHAN-PC Install Autodesk® Revit® 2016 Succeeded
2015/12/26:22:19:05 Ethan ETHAN-PC Installing Autodesk® BIM 360™ Add-in for Revit® 2016: ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk Revit 2016" SETUP_PACKAGECODE={7346B4A0-1600-0510-0000-705C0D862004} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=";;;;" ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk Revit 2016" INSTALLDIR="C:\Program Files\Autodesk\BIM360GlueAddins\Revit2016Addin\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2015/12/26:22:19:17 Ethan ETHAN-PC Install Autodesk® BIM 360™ Add-in for Revit® 2016 Succeeded
2015/12/26:22:19:18 Ethan ETHAN-PC Download Play CMILM2016 http://edutrial.autodesk.com/NET16SWDLD/2016/RVT/WI/{3D6F0F4C-42BF-4584-B497-24782CAA8535}/CMILM2016...
2015/12/26:22:24:09 Ethan ETHAN-PC Download Aborted CMILM2016 http://edutrial.autodesk.com/NET16SWDLD/2016/RVT/WI/{3D6F0F4C-42BF-4584-B497-24782CAA8535}/CMILM2016...
2015/12/26:22:24:09 Ethan ETHAN-PC Install Autodesk Material Library 2016 - Medium Image Library Failed Download Failed, Installation aborted, Result=1603
2015/12/26:22:24:14 Ethan ETHAN-PC Rollback Autodesk® BIM 360™ Add-in for Revit® 2016 Succeeded
2015/12/26:22:35:26 Ethan ETHAN-PC Rollback Autodesk® Revit® 2016 Succeeded
2015/12/26:22:40:00 Ethan ETHAN-PC Rollback Autodesk® Revit® Content Libraries 2016 Succeeded
dzanta
the installation log shows you have a 1603 error which is pretty common when it gets to the material library installation portion.
I would suggest the following:
1.  Uninstall any C++ and .NET files you have on your system.
2.  Install Revit again
Dzan Ta, AEE, ASM, ACI.
Autodesk Community | Twitter | YouTube | Facebook | LinkedIn |
Win 11 Pro/DELL XPS 15 9510/i9 3.2GHz/32GB RAM/Nvidia RTX 3050Ti/1TB PCIe SSD/4K 15.4" Non-Touch Display
David_Knight
in addition to turning off your firewall you should disable your antivirus.
I've also found deleting all the files in your temp directory can fix installation issues.
How do I disable my antivirus so that I can install Revit?
My computer is brand new and haven't installed anything yet.
dzanta
depending on the computer manufacturer and OS, typically Windows OS has Windows Defender already installed.  Just search for that and disable within the application.
