Installation of Revit 2017 Content Libraries
IMCornish
IMCornish
I have read solutions for the installation of 2015 and 2016 Revit Content libraries which apparently also apply to 2017 but since the first step is to find 'Autodesk Revit Content Libraries 2017' in your Control Panel's 'Programs and Features' and it does not exist I would ask how do you actually install the Revit 2017 Content?
See snipit below of my 'Programs and Features':
undefined
Revit 2017 is installed, as can be seen, but no Content Library!
Any ideas
Andrew Robertson
Chartered Architect
Robertson Partnership
Truro. UK
Replies (62)
L.Maas
Something did not go ok with the installation I think.
Screenshot from my computer
undefined
What I normally do when installing a new version is to completely download (browser download) everything from the server, before installing it.
Content issues seem to be often caused by, that at time of installation, content files are goiing to be downloaded. When than an error occurs you run into these kind of problems.
Maybe you can check your journal files to see if something got reprorted
Louis
Please mention Revit version, especially when uploading Revit files.
RDAOU
@IMCornish
If you go for the webinstall, you will always face this problem...Best to download on your PC then install locally.
2017 dlm files can be found on the following two lonks --->> HERE PART 1 and HERE PART 2 (Alternatively; you can download from your account management or Adsk Dsktop App; however, using a different method than webinstall/install now)
Extract them both then run the installation again and install the content library
IMCornish
Had this response from Autodesk:-
Thank you for your recent support inquiry.
As concerns  missing libraries you may try to follow these articles:
https://knowledge.autodesk.com/support/revit-products/troubleshooting/caas/sfdcarticles/sfdcarticles...
But if the libraries are not installed you may download US Imperial and US Metric libraries from this temporary link: https://we.tl/JTBZvoDjJ6
UK library: https://we.tl/mHfNvjSaTk
Belgium library: https://we.tl/j8e5yqow3x
and the please unpack them to these folders
c:\ProgramData\Autodesk\RVT 2017\Libraries\US Imperial\
c:\ProgramData\Autodesk\RVT 2017\Libraries\US Metric\
c:\ProgramData\Autodesk\RVT 2017\Libraries\UK\
c:\ProgramData\Autodesk\RVT 2017\Libraries\Belgium\
respectively.
Let me know if you need any other country libraries.
Not surprisingly the first two suggestions would not work, since they arrived at the original problem I had pointed identified, however I resorted to the download option and instaled them succesfully.  This may be what RDAOU may have been suggesting.  The sad thing though is that whilst I am forced to mark this as a solution  it isn't really since the installation software should work.  Whilst I love the software this 'woolly' ending is typical of Autodesk and their attitude to their software, or it seems to me at least.
Andrew Robertson
Chartered Architect
Truro. UK
Is it possible to have the french version of content Libraries ?
I am downloading the Belgium one but am not sure they are the same.
Unfortunately the download of US and Imperial Content Library does not exist anymore in the first link. We hope referring to anothrt valid link.
regards...
2016 revit türkçe olarak family dosyası istiyorum çok zorlananıyorum malzeme bulmada yardımcı olursanız mail adresinden ulaşırsanız sevinirm. turkey family istiyorum.
yalcin_simsek_57@hotmail.com
Tony_Michniewicz
We've recently identified a sporadic issue that will result in content not being installed via the Revit LT 2017 web installer. After our investigation, we found that a required content file is not always included in the extracted files and its absence results in the installation bypassing Revit content files. We are investigating the root cause of this problem and hope to have a resolution in place soon. Until then, the following steps will allow you to work around this issue:
  1. From this post, download the Revit_2017_MasterXML.zip file and extract the contents to a local folder.
  2. Download and run the Revit LT 2017 web installer, Revit_LT_2017_G1_Win_64bit_wi_en-US_Setup.exe.
  3. When the initial Autodesk Revit LT dialog is displayed, click Cancel.
  4. Copy the master.rlt.xml file that was extracted in step 1 and paste it into the C:\Autodesk\WI\Autodesk Revit LT 2017\Content\Revit folder.
  5. Launch the Revit LT 2017 installer using the Revit_LT_2017_G1_Win_64bit_wi_en-US_Setup_webinstall.exe that should reside in your Downloads folder or the folder to which the original Revit_LT_2017_G1_Win_64bit_wi_en-US_Setup.exe was downloaded.
  6. Step through the installation and when you get to the product selection page, expand the Revit LT 2017 Content Libraries entry and verify that the list of content packs is populated and at least one of the underlying option is selected.
  7. Collapse the Revit LT 2017 Content Libraries entry and click Install.
At this point, we've only seen this problem occur with the Revit LT 2017 web installer but based on the numerous reports of Revit content installation problems, a similar problem may impact other Revit versions, including previous releases. For this reason, I've attached zip files that contain the master XML files for each version of Revit 2015, 2016, and 2017. Once the appropriate master XML file is extracted and copied to the appropriate ...\Content\Revit folder, the installation of Revit content should complete successfully.
Tony Michniewicz
Autodesk Revit QA
Tony Michniewicz
Revit Software QA Analyst
darrenpedder
Tony,
I have had the same issue on a number of 2017 updates (LT Suite), for which your workaround works. I have now updated 7 workstations to 2017 and they all have this problem. Why has Autodesk not corrected this since your post on 20th May ?
I now have to do this workaround 7 times - and then have to manually update the templete paths as well.
Is there a faster method to this ?
xtianparedes
Community Visitor
Community Visitor
Dear Andrew Robertson
Can you please attached the US Imperial and US Metric libraries in a new temporary link again, becuase these don´t work anymore
Christian A P
darrenpedder
2017 attached:
Thanks for the info Tony.
Couldn't workout why all the training video's show templates and families working correctly, I've just spent a 1/2 day researching and fixing this issue for a trail version which only lasts for 30 days.
Not a very good track record to report back to my manager who is deciding which of three products our company will be using, I've been assigned the Autodesk product.
Regards.
ASCunningham
Have been trying to figure out this problem for sometime now. These steps worked for Revit 2017. The folder paths and file names were a bit different but replacing the XML files within the Revit 2017\Content\Revit folder worked. Hope this is fixed for future release as I know that R2016 had the same problem.
ASCunningham
arkelec
Hey, Autodesk - if you read this - please, please please look into making things easier for the users who don't have a IT team to deal with fixing these problems.
I have spent the last TWO DAYS going around in circles because these problems exist.  And I still haven't resolved my initial issue.
Many thanks.
Hi Tony,
I am having the same issue with Revit LT 2017, but am not having any success with your instructions. I copied the files to the right folder and the US Imperial and Metric now show up under Content Pack in the installer. When I install the content libraries, it all seems to go well, but when I open Revit I still get an error message that the default family template file is invalid.
Because the content pack seems to be installed but not loading, I tried the steps here:
This also didn't help. I seem to be going in circles- any additional help? I have no IT department, just me, and I have no idea what to do next.
Thank you.
wally111
Observer
Observer
the UK path fom we transfer   https://www.wetransfer.com/downloads/798ae737d92f6cb1f466c20b0e1b593120160505065313/bed62d
tell me that isn't available anymore.
I really need to have the library and templates of revit 2017
Regards
Walter
The best method -as I see- to fix this problem is to:
1-  uninstall "Autodesk Revit Content Libraries 2017" using Microsoft application Tool "MicrosoftFixit.ProgramInstallUninstall" which could be downloaded from Microsoft website. I have been attached it here.
2- Reinstall the "Autodesk Revit 2017". Ensure that "Autodesk Revit Content Libraries 2017" option is checked while keeping your PC connected with the internet. This will take a while but do not disconnect the PC from the internet during this time.
3- When it is finished, you will find that "C:\ProgramData\Autodesk\RVT 2017" folders and their contents are exist with a size of about 2 Gb.
arkelec
Tony posted further down page with master libraries listed, here's the link Revit 2017 Master XML
wally111
Observer
Observer
It tells me that this folder was already uninstalled...but appears in -programs data -in my computer but the folders are empty...What can I do?Theres a possibility to install tehe?
Regards
Walter
Type a product name
______
icon-svg-close-thick
Cookie preferences
THIRD PARTY SERVICES
icon-svg-hide-thick
icon-svg-show-thick
Qualtrics
Akamai mPulse
Digital River
Dynatrace
Khoros
Launch Darkly
New Relic
Salesforce Live Agent
Wistia
Tealium
Upsellit
CJ Affiliates
Commission Factory
Typepad Stats
Geo Targetly
SpeedCurve
Qualified
icon-svg-hide-thick
icon-svg-show-thick
Google Optimize
ClickTale
OneSignal
Optimizely
Amplitude
Snowplow
UserVoice
Clearbit
YouTube
icon-svg-hide-thick
icon-svg-show-thick
Adobe Analytics
AdWords
Marketo
Doubleclick
HubSpot
Twitter
Facebook
LinkedIn
Yahoo! Japan
Naver
Quantcast
Call Tracking
Wunderkind
ADC Media
AgrantSEM
Bidtellect
Bing
G2Crowd
NMPI Display
VK
Adobe Target
Trendkite
Hotjar
6 Sense
Terminus
StackAdapt
The Trade Desk
RollWorks
Your experience. Your choice.
