Installation folder
Installation folder
Installation folder
After chosing a folder for the Installation, it is not possible to continue. Each time I push on the install buttom it opens another window to choose the drive to install and so on...
I'm using windows 7, Trying to install Revit 2015 and 2016 (the same problem)
dzanta
are you redirecting the installation to a different drive or a different folder?  Autodesk software defaults to C Drive and sometimes has hiccups installing to other drive.  You should be able to install to any subfolder within C Drive.  If not, try redownloading the installation software files.
Dzan Ta, AEE, ASM, ACI.
Autodesk Community | Twitter | YouTube | Facebook | LinkedIn |
Win 11 Pro/DELL XPS 15 9510/i9 3.2GHz/32GB RAM/Nvidia RTX 3050Ti/1TB PCIe SSD/4K 15.4" Non-Touch Display
Thank you for the quick replay! no I have to install it on a different drive then C ! my derive C is all most full so it is even not possible to install it on C
dzanta
You have three options:
1.  Clean up your C Drive to install the software on C Drive
2.  Remove any Autodesk software already installed on D Drive then try again
3.  If you already have Autodesk software installed on C Drive, they may be conflicting with the installation of Revit on D Drive.  You will have to figure out that conflict before installing on D Drive
