installation error 1309 when installing Revit 2017
My laptop is equipped with Windows 10, but when I try to install Revit 2017, an error pops up claiming I require Windows server 2008 R2 SP1.  What do I do?
jasmin.gonzalez
Hi @Anonymous Welcome to Autodesk Community!
Please check out Revit 2017 system requirements as well as the Windows 10 tips to see if it helps your issue.
Let us know if it works.
Jasmin Gonzalez
Thank you for your help.I have the same question.Except for your answer.
lynn_zhang
Hi @Anonymous
Could you please try the below solutions for this error?
Error 1309: "Error reading from file" (during installation)
Error 1309. Error reading from from File. Verify that the file exists and that you can access it.
Hope it helps.
Lynn Zhang
