Message 1 of 8
I need to combine the views of a couple of projects together in a third project so that I can compile annotated sheets with the different views.
When I try Insert Views from File command, and pick the file, I only see a couple of views - there are no floor plans, elevations, area plans etc.
I've also tried Insert 2D Elements from File too and I get some of the elevations (not all of them for some reason) and of those which do appear, they look ok in the preview but don't copy across and I get the error:
"Some dimensions were not copied because they could not find a reference."
What do I need to do in order to get the views I need from other projects so I can use them?
