Inserting a Window into a Curtain Panel Family
Message 1 of 8
I am trying to insert a window into a curtain wall via the curtain wall panel. The window, not being a curtain panel window, I have tried inserting it into the family but I cannot as it is wall hosted. Is there anyway I can get around this?
Replies (7)
Message 2 of 8
ennujozlagam
hello, you cant insert wall hosted window in curtain wall panel, you try to nest your window into curtain wall panel. thanks
Message 3 of 8
I've tried to nest it via load into project, but it cannot as Revit asks for a wall to place window in. I may be missing something here but does the window properties need to be altered so that it's not wall hosted?
Message 4 of 8
cbcarch
Make a thin wall type. Then, use it as the curtain panel.
Then, you can insert the window into it as it is a wall.
Cliff B. Collins
Registered Architect The Lamar Johnson Collaborative Architects-St. Louis, MO
Message 5 of 8
TB7
I started my window (for the same reasons you want windows in your panels I guess) as a generic model (the template which requires no host) and changed the category to window. This lets you nest the window in your panel family.
Message 6 of 8
Hey Guys!
Pretty sure I just figured this one out.
If you open up a curtainwall door family and change the family category to "window", you can then model the panel to look like whatever window type you want, file-save as, and load it into the project. Once it's there, you can click the panel type and change it to your new window. Since it's a window type, it will also appear correctly on your Revit-generated schedules.
Message 7 of 8
Thank you! Great solution, you are the man.
Message 8 of 8
drosenthalUQMVQ
I do this too but do you know how to control the "offset" I don't see a parameter for it since it isn't a curtain panel family
