Insert tin surface from C3D to Revit
qchenTPPXV
qchenTPPXV
Greeting,
I have created a tin surface in C3D and tried to insert it into Revit. I tried both import or insert CAD, neither of them works. I know one workaround is to create a thin 3d solid out of the surface. Hope you can give me other better solutions.
LyleHardin
Install Object Enablers and Explode.  Then Import into Revit.
handjonathan
Hi @qchenTPPXV
Thanks a lot for posting your question to the forums!   Have the solutions suggested by @LyleHardin @barthbradley helped with your issue?
We look forward to hearing back from you with more information so we can help you as a community! 
Jonathan Hand
Technical Marketing Manager | Construction
qixing_chenZEV3X
Thank you for sharing. Do you find the surface boundary is larger than its from C3D?
