Insert floor not in the template
Message 1 of 8
i have revit in engligh but I noticed there aren't the same kind of element for floor for version of revit in other language?
To find this have to load with load families?
Have to choose in a kind of list like in the attached?
Replies (7)
Message 2 of 8
ennujozlagam
@Anonymous hello, you have to set your file locations from options. thanks
Message 3 of 8
Please can charge me template please?
Or say me where found this?
Message 4 of 8
Sahay_R
For the Floor, you will need to create a new floor type.
Alternatively, create a floor object with the desired type of floor. Click on it and hit CTRL-C, go into the file where you want to add the floor and hit CTRL-V. That will add the floor to your project.
For templates -
Location of templates -
https://knowledge.autodesk.com/support/revit-products/learn-explore/caas/screencast/Main/Details/471...
Rina Sahay
Autodesk Expert Elite
Revit Architecture Certified Professional
Message 5 of 8
Anyway if I want to download family from news templates which can I choose?
Message 6 of 8
Sahay_R
What you have in your picture is Revit's library. There is also a folder called Family Templates which will get you started with building your own families.
Rina Sahay
Message 7 of 8
Sorry but I haven't undrestand the process.
For that floor with architectual template I only have floors of attach 2. To have floor attach 1 have to insert a specific other templates in file location from option in addition to these already insert (attach 3) ?
Undrestand the copy/cut from other project to project using, go and is usefull but would to undrestand really what is the procedure for the future.
Really thank's.
Message 8 of 8
Sahay_R
Here is what you need to do to set up a new Floor Type -
Create a Floor.
Properties>>Edit Type>>Duplicate>>Rename>>(give it a new name)
Make the changes that you need to the parameters. That could be structure, material, etc.
To make sure that the floor type is there in your project - in your Project Browser look at the Families. You should see your new Floor Type under Floors.You are all set!
Rina Sahay
