Insert a Row in a Key Schedule
6 REPLIES 6
PhilvK
7213 Views, 6 Replies
Is it possible to insert a blank data row in a key schedule between 2 rows that have already been numbered, or would you have to go with the row being inserted at the end and renumber all rows manually if you need a row inserted and renumbered somewhere specifically?
6 REPLIES 6
robert.klempau
in reply to: PhilvK
Hello @PhilvK,
It is not possible in Revit to insert a row between two other rows.
But what you could do is write a Dynamo script that does that for you.
If my post answers your question, please click the "Accept as Solution" button. This helps everyone find answers more quickly!
Kind regards,
Robert Klempau
Senior Consultant AEC
Cadac Group AEC BV
PhilvK
in reply to: robert.klempau
Thank you for the info. Unfortunately, I am not familiar with Dynamo.
in reply to: PhilvK
Not automatically.
You need to introduce another column [Group] to sort the rows in addition to the number column [Key Name].  When you insert a new row it will come in the bottom, you just enter a new number in the [Group] column for the row to bring it to the proper location.  Then delete the Key Name value for the same row and hide the [Group] column to have blank row in the middle of your schedule.
mviscetto
in reply to: ToanDN
Perfect.
Thank you for that.
Michael
Drafter18VPD9
in reply to: PhilvK
How are we 7 years past this and Revit still won't let you insert a row in a schedule where you need a row. The official statement for generic, non-model-linked, text schedules is a janky workaround.
The "Insert Data Row" button doesn't even follow the behavior described here. Rows are inserted at seemingly random intervals starting halfway into my schedule, independent of what I've selected (to tell it where to insert, as is typical table functionality)
This is insane.
Just let me make a table, jeeze. Extremely frustrating lack of what seems like obvious features to include.
inbarl
in reply to: Drafter18VPD9
im also asking how come not to insert a row in the middle......
