Increase print resolution
cbt990
Message 1 of 10
cbt990
I am trying to do a production-quality print. My detail level is set to Fine, and my Render quality is set to Best. The raster quality is set to Presentation. The DPI of the PDF is set to 1200 ppi. The result looks like this:
Revit is amazing
Replies (9)
Message 2 of 10
L.Maas
In the view select the camera view (the box).
Then Size Crop
Check Scale locked Proportions
Set the width (or height) to a higher value
Note that the amount of pixels goes up quite quickly so render times will increase significantly fast
Louis
Please mention Revit version, especially when uploading Revit files.
Message 3 of 10
mhiserZFHXS
Just a note, detail level doesn't have anything to do with this. Element visibility can be determined by detail level, so say the door stops in a door family are only set to show on fine detail, and the frames are just rectangles at other levels.
Message 4 of 10
cbt990
This is what my Size Crop dialogue looks like:
Revit is amazing
Message 5 of 10
Did you set Resolution?
Message 6 of 10
cbt990
What function is that dialogue under?
Revit is amazing
Message 7 of 10
L.Maas
Ah ok, you used a standard 3d View not a camera view.
Try it with a camera view
If desired you can set it to orthographic if you do not want perpective view.
Louis
Message 8 of 10
It is under Rendering.  Are you rendering the 3D view or is it just a Realistic view?  Can you show a capture of the entire view and properties for context?
Message 9 of 10
cbt990
I created a 3D view using a camera, rather than the default method.
Here are the settings available to me now (includes a bit of an inactive viewport showing the camera object in the active view):
Revit is amazing
Message 10 of 10
So it is just a realistic view, not a rendering.  Did you place the view on sheet?  How big is it when placed on sheet?
